Where the hell does Intel find their marketing people.
But would Lisa Su be as content to take such a meager settlement as her predecessor, if history repeats itself again?
What's the story behind this? Did intel really stick a 1151 cpu on top of a 2066 substrate? Did anyone de-substrate it yet and stick it into a regular 1151 mobo?![]()
Did someone say glue?
Were they charging more and more. From my perspective buying machines, it seemed they were charging about the same for very gradual improvements. Which is about what you expect when the marketplace stagnates.
Intel has a few choices, lower prices, expand outside of the x86 game, or improve the product significantly.
Also, AMD looks attractive for data center use, but doesn't look all that compelling for desktop use unless you already have some use that is already multi-threaded, and multi-threaded WELL. Apples to apples for many common things performance is similar and prices are similar. So for the consumer market, Intel also has the option of simply leaning on/bribing devs to not improve multi-core support further. That really doesn't work at the data center level though. SO there they spread the FUD of "nobody got fired for buying intel".
Intel being intel, I suspect they will respond with better hardware. This about buying some time to push it through the pipeline. AMD's chipsets aren't exactly famous for being ultra good and stable on day one, so the data center market is going to need to see some proof of a quality product there before you see any big shifts.
it should hold 40% lower price due to the shrink
In a presentation slide, Intel alleges that AMD’s EPYC server processors are actually repurposed desktop products comprising parts that have merely been “glued together.” They claim that this design results in “inconsistent performance” and additionally accuse AMD of having a poor track record and being an inconsistent supplier.
Ah, the "glued-together" dies. Let's forget how AMD's Zen cores actually look like they were architected from the get-go for modularity and scaling, which has allowed the company to keep die-sizes to a minimum and yields to a maximum. This means that from a same-sized wafer, AMD can make more Ryzen/EPYC processors (because yes, that's the beauty of it, they're almost interchangeable), and in all likelihood, have more of those full-fledged dies without any defects that affect yields.
It think Intel was moving towards a fairly agressive price differentiation in their plataforms, this would allow them to add higher tiers first, then milk things nice and slow.For the i7-7740X and the i5-7640X, yes that is what Intel did. No, nobody has removed one from the substrate, but Intel would not have created a special die just for these models. It would cost too much. So, yes, they are wasting die space for integrated graphics that aren't getting used. Funny thing, though, is that the X299 and Z270 chipsets are also identical, and yet Intel charges more than double for the X299 ($17 for Z270 and $40 for X299).
Quite the conspiracy... lol did you even attempt to do the math. TR doesn't start at $1000, the 12c starts @$800 and the next one, the 16c, is $1000. Intels 12+ cores are greater than $1000. Not sure why you keep bashing AMD on price when in comparison to Intel they are DIRT CHEAP and Intel is fleecing you.Any intel CPU over $500 is way overpriced. If AMD can really put pressure on Intel on those it would really help everyone. But it looks AMD and Intel must have some of non-aggression pact with Threadripper starting at $1K. It will be along time before any benefits trickle down to the rest of us peons.
Summary: Intel's advertising department in panic mode
One presentation stuck out more than the rest. Intel presented a deck that outlined what it considers to be its advantages against AMD’s EPYC CPUs. The slides generated a lot of controversy over the last week, but they haven't been presented in context. We’re going to fix that.
