Intel DH67CF B3 _ CPU cooler?
Cov
Hi, is this motherboard only supposed to work together with a push-pin CPU cooler?
I ask because there seems to be a problem when using a CPU cooler with backplate.
Here is a picture of DH67CF's rear where this chip (circle) gets in the way:
This is a picture of a typical backplate:
That chip could prevent the DH67CF to be used with a backplate as can be seen here (different mainboard):
My question is whether the revision B3 still has this problem.
Thanks
Dunno about the B3 rev but 2 1mm washers on each hole will solve the issue so no big deal.
