Intel DG965WH and high voltage memory
djnes
Has anyone attempted to use higher voltage memory on the Intel DG965WH? I'm buying this board from another forum user, and I'm wondering if my Ballistix will work in it? I'm going to test the board out first, before buying any new components, and I'd like to be able to use my Ballistix memory to test right now, instead of buying new memory right away. This board will eventually go into my wife's PC in the spring.
I wouldn't recommend buying with that combo in mind only because you're bound to have issues unless your particular set of Ballistix happen to boot at 1.8V. Personally, I don't see that as being very likely, but you never know. My memory boots at 1.8V with no problems and it's known for being high voltage memory.
If or when I buy memory for this board, I'll be sure to get something rated at 1.8V. I probably won't even try it with my Ballistix....because it may not boot anyway.
If you're going to buy memory for it anyway, you can try your ballistix. I'm just thinking that the chances of success aren't very good :(.
