Intel Delivers the World's First 6-Watt Server-Class Processor
HardOCP News
[H] News
Intel Corporation introduced the Intel® Atom™ processor S1200 product family today, delivering the world's first low-power, 64-bit server-class system-on-chip (SoC) for high-density microservers, as well as a new class of energy-efficient storage and networking systems. The energy-sipping, industrial-strength microprocessor features essential capabilities to achieve server-class reliability, manageability and cost effectiveness.
No mention of what GPU is on this SoC? Sure nope it's not the super crappy PowerVR still...
They seem to be aimed squarely at those SeaMicro atom servers, so they may only be available on multi-cpu server boards that sit on some sort of yet-discussed Intel backplane.
These may be intended to be entirely headless, or it may be intended for multiple CPUs to share some off-chip GPU.
I can't get my head around the fact that Atom processor can be used in servers. Storage servers maybe, but not web server or application server or anything else.
FTFA
"More than 20 low-power designs including microservers, storage and networking systems use the Intel Atom processor S1200 family."
FTFA
Yeah I saw that. I'm just wondering what they mean by microservers. As I said I can definitely do with a low power storage server, but not much else. At the moment I'm using a Llano A4-3300 as my storage server and it works amazingly well.
Why not? People used to stick one Pentium Pro into a server and be all like, "This thing has 192 MB of RAM and runs at 180 MHz. We have four 4.3 GB SCSI drives in RAID5 which gives us more storage and processor power than we'll ever need. Our entire business enterprise will run from two of these monsters." Atoms are lots faster. :)
The funniest part of this release is that AMD will be selling Intel's processors via SeaMicro.
A lot of web and application servers basically are storage servers though. A lot more could be if they'd do away with their bloated overhead.
At this point if it's making AMD money then they better do it. I'm not an AMD (processor) guy but that doesn't mean I don't want them to give intel a good run for their money.
AMD could probably produce a very competitive product with something adapted from their Zacate chips. A Zacate chip without the GPU would have a tiny die size and would likely match TDP with the Atom.
Of course something likes this costs money to develop which AMD isn't exactly rolling in.
They're doing that, but I believe focusing on ARM instead, likely for perf-per-watt purposes.
The new Jaguar-based chips offer TDPs all the way down to the 4.5W level, but bear in mind that we're talking AMD here so that 4.5W likely has a good portion dedicated to the on-die GPU. While that's great for GPGPU purposes, these are likely different workloads and a different market entirely. The 4.5W Temash chip is also an SoC and not a CPU.
I'm not sure how they're going to go about it, but given SeaMicro fabric is flexible I wouldn't doubt that AMD would sell both ARM and x86-based chips for the microserver market.
Enough 0.01w stuff. Give me 120 core 10ghz! :p
Why? There would be horrible compromises to get a general purpose CPU running existing software (mainstream architectures) at 10GHz.
But if you want 120 x86 cores, Xeon Phi has 60 or 61 cores and you can plug in as many as you have PCIe slots. :p You'll only get ~1.1GHz from those, but they are computational beasts, and can run x86 software too.
Like I mentioned in the thread on the Intel forum, hopefully this goes on an Atom server board someone could buy from Newegg.
It'd make for a nice fileserver or pFsense router.
Just looked up the specs...
There are 2 1.6GHz models, one 6.1W and one 8.1W: 2c/4t, ECC support, DDR3-1333. Then there's an 8.6W model: 2GHz, 2c/4t, ECC support, DDR3-1333. All support VT. All are made on 32nm LP process. I wonder if there's a HTT-like (err QPI-like) glueless connection between the CPUs to allow, say 4 modules or more to share a single board in a high density server, or some other kind of scalable CPU-CPU link. The BGA on the CPU has many more balls for some reason or other. (And this would kind of negate SeaMicro's custom fabric advantage, allowing competitors to get it "free" with Atom.)
Anand thinks it's a new core due to the new BGA "socket", and that it's not just an existing product that's been tweaked.
At first I'm thinking it's Medfield on a desktop/server board, but that is another possibility-- an entirely new architecture with a more featured chipset (supposedly integrated on the CPU).
No, the core is likely the same. What has changed is the I/O, IMC, and more PCIE lanes.
It's a different die, but the core architecture is the same.
I can see the Atoms running as domain controllers. Have 2 socket boards with a pair of dual core Atoms. Then run multiple domain controllers. There's also DHCP server and Print Server. Edge Server. There's plenty of uses for it.
Especially if it's for a small enterprise.
Look at the last few CPUs (SB/IB) the fovcus has alll been about power efficiency and low power not pure power sucking powaa. I don't care if the motherboard needs multiple 8 pin plugs andthe CPU sucks down 500w at idle. :D
Also intel said that they were aiming for 10ghz at some point, so thats a promise! (kind of) So you know i'm just holding them to it. :p
Ok so basically either in the next 5 years Intel start working on the 10ghz gazzilion cores, ooor I reccomend someone else to buy an AMD chip. I mean it!
Multiple 8 pin plugs and 500 watts at idle? Does it include a chainsaw?
