Intel Core i9-9900K 9th Generation CPU Review @ [H]
Discussion in 'Intel Processors' started by Kyle_Bennett, Oct 19, 2018.
  1. ceski
    ceski [H]Lite
    84
    Jul 6, 2016
    Oh yeah, it's neat being able to quickly verify these things by simply running Intel's own XTU software side-by-side with your favorite stress test like Prime95 26.6 (non-AVX) or Cinebench. XTU shows the PL1/PL2/Tau values set by your BIOS, even locked down ones like the ThinkPad.
  2. ceski
    ceski [H]Lite
    84
    Jul 6, 2016
    Yes, and if the BIOS has configured the processor to follow Intel specs from the data sheet, the power consumption perfectly matches TDP under sustained load (once PL2 has been exhausted after 1 second), even while under boost clocks. The Stilt did a neat analysis of this.
  3. ceski
    ceski [H]Lite
    84
    Jul 6, 2016
    I'm at work, but here's an example of what I mean on my laptop. After power limit is enforced, the processor power consumption drops to and matches TDP while still boosting above base clocks as much as it can. You can see how Lenovo has juiced a few values.
    Meeho likes this.
  4. Kyle_Bennett
    Kyle_Bennett Editor-in-Chief HardOCP Staff Member
    51,872
    May 18, 1997
    OK.
  5. ceski
    ceski [H]Lite
    84
    Jul 6, 2016
    Sorry, I get passionate about this stuff. Edit: I don't understand the flippant response I guess. Bolded for emphasis:
    This is thrown out the window if using AVX since that apparently uses different voltage tables not accessible by the end user. Just the messenger here.
  6. drutman
    drutman n00b
    48
    Jan 4, 2016
    Amazon had one for 799 USD who in their right mind would pay this for a 1151 CPU?
    I got a 5820K new for $279 at our local microcenter.
  7. ChefJoe
    ChefJoe Limp Gawd
    132
    Oct 25, 2009
    Only so many hours in the day and I hope the your 9980xe review doesn't sour things with your reps, but I'm still very curious what H finds trying to overclock a 6 core 9600k vs the similarly priced 6 core 8600k (which was in this 9900k review).
  8. Kyle_Bennett
    51,872
    May 18, 1997
    Dunno. The new Intel PR guy does not seem to be put off by the truth as much as the last one.
    Still trying to get CPUs. Asked again today.
    Armenius and ChefJoe like this.
  9. ChefJoe
    ChefJoe Limp Gawd
    132
    Oct 25, 2009
    The world would be a better place if press contacts were more "Ryan Schrout" fans than devotees to the "cult of the reality distortion field." I hope they come through with samples. I've seen very few 9600k reviews out there, still.
  10. OrangeKhrush
    OrangeKhrush [H]ard|Gawd
    1,356
    Dec 15, 2016
    It may be that before people were more naive to it and it wasn't seen to be a factor, and reviewers probably didn't pay attention to it which maybe led to the market naivity. But the last few years in technology and automotive markets "efficiency" has become a very concerted market awareness, now reviewers are paying more attention to this and in turn people are becoming aware of it. This is just on the efficiency side.
    As for Intel purporting stock results based on core policy manipulations, that is misrepresentation and touting but we know Intel has a rich history of believing rules and should I say International Rule of Law does not apply to them.
  11. Kyle_Bennett
    51,872
    May 18, 1997
    There is not a standard for "TDP" so you can call it anything you want. It may mean one thing to one company and something totally different to another, which is exactly what we have here.
    Armenius likes this.
  12. Armenius
    Armenius [H]ardForum Junkie
    15,903
    Jan 28, 2014
    Intel has a product line for energy efficiency, though. It's called Atom.
  13. Brian_B
    Brian_B 2[H]4U
    2,089
    Mar 23, 2012
    It does have some parallels with Netburst. Not in a direct way, but there we saw that the architecture became power limited - you could throw more whatevers at it, but ultimately you just couldn't escape a set power envelope inherent to the manufacturing process and design philosophy.
    Intel dropped back and put a larger emphasis on power, rather than speed, and speed came back up as a result.
    Now, I think we've found the edge of that envelope again, at least with Intel's current manufacturing and design. You could try to throw more cores, or more Ghz at it, but your just constrained by the power envelope no matter which way you move.
    Shows how much the delay in 10nm is really hurting Intel right now. It ~may~ be possible to design around it, and with a new architecture wring some more speed out of the current process, but I'd put the return on that pretty low, and the effort/R&D required for that pretty high.
  14. lebibz
    lebibz n00b
    1
    Nov 16, 2018
    Having trouble with my 9900k. Started fine, loaded windows fine, gamed for an hour and a half and it hard locked. Windows couldn't boot. Today I've tried removing all but essentials, rolled the ram, replaced the Auros Pro with an MSI Carbon. Still getting WHEA uncorrectable error when trying to boot off usb or m2. Only other thing it could be is the RAM I can't try elsewhere/get other stuff, unlikely to have two dud sticks though.
    Temps were quite fine, H110 was mounted well and had perfect mating. 40-50% cpu usage in game. Stayed below ~48c the whole time. Odd failure.
  15. Ghoststalker
    Ghoststalker Limp Gawd
    442
    Jun 4, 2001
    Will my h150i pro be adequate for cooling this beast? Hoping for a 4.8 or 4.9 all core oc.
  16. shaolin95
    shaolin95 2[H]4U
    2,785
    Jan 5, 2006
    Should be able to handle that easily/
  17. alxlwson
    alxlwson You Know Where I Live
    5,463
    Aug 25, 2013
    It's over 9000. Teehee!
    cybereality likes this.
  18. cybereality
    cybereality 2[H]4U
    3,745
    Mar 22, 2008
    alxlwson likes this.
  19. Ghoststalker
    442
    Jun 4, 2001
    I'm seeing core temps in mid 80c range at stock doing the 264 blender test. Seems high, I'm going to remount hsf
  20. fullvietFX
    fullvietFX [H]ard|Gawd
    1,663
    Sep 1, 2004
    This is the first time I didn't bother overclocking my CPU.
  21. PhoenixGenesys
    PhoenixGenesys Limp Gawd
    423
    Jun 7, 2007
    This piece of advice might come several months late, but have you considered running Memtest86 at least for 1 pass to make sure your RAM isn't faulty?
  22. FedericoUY
    FedericoUY n00b
    27
    Sep 2, 2016
    So solders are not good on this samples? Ohh old good 2600k...
    Are 5.2ghz freq achievable @ low temps @ good sample?
  23. arnemetis
    arnemetis 2[H]4U
    2,376
    Aug 2, 2004
    The fastest 9900k at silicon lottery is 5.1ghz for $899, so I'm thinking you would have to have a golden sample to hit 5.2.
  24. FedericoUY
    FedericoUY n00b
    27
    Sep 2, 2016
    So only .2 ghz extra on all cores must be a golden sample? Mmm...
  25. arnemetis
    arnemetis 2[H]4U
    2,376
    Aug 2, 2004
    Exactly. There simply isn't much headroom past 5ghz on these chips. Also remember that the stock 5ghz boost is not for all core, the 9900k's all core boost is 4.7ghz so that makes a 5.2ghz a .5ghz better boost on all cores. True that isn't groundbreaking but that's all that can be expected for this chip.
    Solhokuten and Darth Kyrie like this.
