The V10 works though. Best air cooler out there. I bet you could get your OC down to 69C with it.
off the top of my head I idle at 33-38 and under load I believe highest I've seen is 60.
I'll update my post when I get on my desktop ( currently on laptop ). What's most peoples ambient temps at? My 4.0 OC seems to be running a lot cooler than most peoples. off the top of my head I idle at 33-38 and under load I believe highest I've seen is 60.
Edit: Heres my idle temps. @Farkle: Yes that was under stress testing. During stress testing I saw it hit 60 once and then settled down to stay at 58-59.
Edit2: Coretemp and Realtemp are pretty close together, but the gigabyte program is quite a bit lower. Is it because thats the socket? anyone know how it works?
Yeah I know that. I don't want it enabled. Besides folding I run Boinc programs and you cant have HT enabled with some of those. Besides I leave it off anyways, I need more voltage to get 4.0 stable with HT on. 4 more threads isnt needed for me.
The V10 is basically putting a mini case inside your case. You're better off going with the H50 but getting 4ghz on a c0 is pretty much luck on the batches if you're on air cooling but if you upgrade to water cooling its pretty easy to get 4ghz.
If I'm going to install something that massive in there I'd probably just move on to a watercooling setup.
Anyhow I look forward to seeing your numbers once you get it on there.
The V10 smokes the H50--smokes it. The H10 doesn't do much better than the Cogage.
Unless I got a ban fan, the Cogage's fan is way too noisy. And even slowed down it hums. With all the problems I had mounting the fan, I'm not looking forward to putting another one on it. I have a PWM Gelid Silent 120mm coming tomorrow too. Did you hear yuor Cogage fan? Was it loud?
Not really no, It's barely better than the TRUE and you have to make sure that the TEC can be cooled well and also its huge and expensive. Totally not worth it.
Although you said you were hovering at 89C, so that's another 15C I can push it.
http://www.legitreviews.com/article/926/4/
http://www.legitreviews.com/images/reviews/926/i7.gif
Direct comparison V10 vs TRUE 120
10C difference between the V10 and TRUE 120. The thing is, you have to run that sucker hot to get the Peltier system to work, and once it's working, it kicks ass. If you look closely at the OC where the V10 doesn't do as well, you will see that it is a much lower heat test than using the 920 at 4Ghz. The test above is at a heat pumping 4Ghz.
Actually, here's a review that compares the H50 and V10 and the H50 actually does outperform the V10, by .2C and yes, that's "point2C" as in dot2 or .2!! And that's at, like I said, below 4Ghz, at 3.66Ghz. The hotter it gets, the more the TEC system kicks in.
http://www.rwlabs.com/article.php?cat=&id=203&pagenumber=5
Fair enough, thoguh thats the BIGGEST difference i've seen. The main point is the size and price...
£91 for the V10
£60 for the H50...
£44 + fan
Now if you consider the fact that all of these will be able to handle an overclocked i7 at the same speed stable and good temperatures, regardless of a maximum of 10c cooler for the V10, i think you'd be a bit silly to go for it, unless of course you hav the money and anal enough to want say an improvement from 80c to a hopeful 70c.
I agree with that. But the V10 still smokes the H50.
I disagree, strongly. But each to their own.
There are hardly any reviews comparing the two, i have no facts. I do not need facts to disagree with an opinion.
I have the BIOS set to a Vcore of 1.5, but it shows only 1.36 tops in CPUz. Can someone tell me what is up with that? If CPU z is reading it correctly, then it was simply undervolted at 4Ghz.
I found CPU-Z to consistently under-report my CPU voltages compared to OCCT. If you are undervolting and really just at 1.36 then whatever cooler you have is performing worse than my TRUE Spirit, if you really are at 1.5v then that's not bad at all.
Your underestimating the h50, it works very well. Most run in the 70's or below at 4ghz. Corsari claims 10c better than the "best" air coolers. Thats a bold claim and I don't say its definitively true. But it is a excellent designed cooler. Where as I don't read many good things about the v10 at all.OK that's fair. When I use the word "smokes" I mean it was 10C lower in the test I provided, if and only if the CPU generates enough heat. It that test, the 920 was clocked to 4Ghz, and it is common knowledge that the 920 runs hot at 4Ghgz, which, in turn, provides a good control to test fans.
So yes, my arbitrary word "smokes" is an opinion. Given the evidence, don't you think 10C could be considered "smoking" the competition when even 1C could make or break and OC?
Your underestimating the h50, it works very well. Most run in the 70's or below at 4ghz. Corsair claims 10c better than the "best" air coolers. Thats a bold claim and I don't say its definitively true. But it is a excellent designed cooler. Where as I don't read many good things about the v10 at all.
I have a fan on each side of the h50 rad both blowing out the back of my antec 300.Yeah the "incredible v10 hulk", Which cause of Its size probably doesn't fit all that many cases, I have an H50(still boxed), As I'm slowly building an i5 computer with It as the case needs filters and the house needs a new window and new weatherstripping[the old window & weatherstripping leaks like a sieve], So I'll sell off some parts to get the cpu and ram(older parts: Intel Q9300[3.51GHz capable], Asus P5K Deluxe, 2GB Patriot Viper pc2-8500 ram[runs at 440MHz @ 2.12v] and a heatsink w/mounting) The motherboard(a DFI LANPARTY DK P55-T3eH9) I'll have enough for on the 1st at least.![]()
Your going to like it, I have the i5750 at 4ghz 1.40v it runs in the 60's prime95+Ibt full load.
Compared with the stock hsf, lol - It would go to the 80's at 3.4ghz
The rad has holes on both side to mount fans, it comes with 4unique screw that fit the holes. I used 2 diagonally on each side to mount the fans. Which left two holes open on the antec rear fan to mount to inside of case (its original place) from the outside with the fatter case screws.Dual fans, push pull, yum, I've got two all picked out too, amazon does a good job on that, I just have to keep from adding to the lists there. I've seen at least one i5 750 @ 4.216GHz.![]()
Better yet, a 920 C0?
