Flexion
- Jul 20, 2004
Need some help overclocking for the first time later this year. I currently have a C0 i7-920 CPU and I want to get a stable safe overclock between 3.5-4.0Ghz. My parts will likely be:
1. Asus Rampage II Gene Mobo
2. Mega Shadow CPU Cooler
3. Silverstone FT02 PC Case
4. Three FT02 180mm Intake Fans / Two 120mm CPU Fans / One 120mm Exhaust Fan
5. XFX 5850
6. Corsair or Crucial RAM, 6-12GBs
Is it worth selling my Summer 2009 C0 CPU for a D0 on an air cooled only system? I was thinking of selling the C0 i7-920 CPU with my Noctua Dual Fan NH-U12 SE1366 CPU Cooler as a set. Get most of what I need for the D0, then aquire the CPU Cooler I really want, the Mega Shadow.
It's not really worth it to sell your C0, because you're talking about 100-200 MHz difference in overclockability tops. Also, not all D0s run on low volts, clock high, or run cooler. I've got one and I had to watercool it for 24/7 use at 4.0GHz, just to keep it under 75C full load. There are folks doing that with C0s on air, so YMMV. IMO it's not worth the trouble.
