HardOCP News
[H] News
- Dec 31, 1969
PC Perspective has posted a review of an Intel Compute Stick today. What good are these itty-bitty PCs? Watch the video review to find out.
Zarathustra[H];1041562239 said:I wonder how well one of these would perform as an XBMC/MythTV frontend.
Are the baytrail Atoms good with HD video decoding?
Zarathustra[H];1041562252 said:It's too bad there is no wired gigabit Ethernet. I guess you could use a USB adapter, but it's only USB2, and now you are adding cost.
I try to avoid using Wifi whenever possible, something that is going to sit stationary connected to a TV would fit the "whenever possible" condition.
Yeah this is what I what I was wondering too. Half the performance of core M processors which makes me doubt...Zarathustra[H];1041562239 said:Are the baytrail Atoms good with HD video decoding?
Also it has 32GB of "storage" is that available, or does windows 8.1 take up some of that space as well.
In the video he said that certain streaming services wouldn't work because of the limitations of the integrated 802.11n wireless adapter (he stated that it peaked at around 40 Mbps out of 54 Mbps possible), but shouldn't an 802.11n device be fully capable of handling the bandwidth necessary for 1080p streaming? I am a bit rusty on my wireless specifications, but I thought Wireless G capped at 54 Mbps, with the same applying if running an N-device in G-compatibility mode. Otherwise, N should be capable of 150, 300, or 450 Mbps, depending on the device that is broadcasting the signal, shouldn't it?
Agreed. Wired connections are always preferable in my house. I've got three access points sharing the load with different networks, but they are still overused when there are perfectly good ethernet ports nearby.
I really like the idea of these "sticks" but I also worry about the HDMI connector taking the full weight of the device. I realize that many TVs have a port or two in a recessed area and are oriented vertically, so the strain would be somewhat minimized. It still makes me cringe though...![]()
Your numbers are pretty spot on I believe. Not that anyone ever sees the peak throughput, but yeah, N should be a lot higher than 40-54Mbps.
Zarathustra[H];1041562292 said:That's the understatement of the day.
Between interference from other wifi access points, cordless phones and microwave ovens, walls, etc and the fact that wifi bandwidth is shared between all connected clients and is only half duplex as opposed to wired ethernet, most people are lucky if they get a handful of percent of the advertised wifi speeds.
I've more or less given up on Wifi for anything but phones and temporary laptop use.
Everything else gets wired ethernet.
Wireless AC routers are so damn fast now, its not that big an issue unless you have a big home.Zarathustra[H];1041562252 said:It's too bad there is no wired gigabit Ethernet. I guess you could use a USB adapter, but it's only USB2, and now you are adding cost.
I refuse to run wireless in my home... so... yeah, this device probably isn't for me.
Zarathustra[H];1041562276 said:I should clarify, yes I know they do some cursory testing in the review, but I need more detail, especially since he mentions high bitrate bluray backups may be a problem.
Also, 23.976 hz accuracy and bitstreaming would be of interest here.
Well, the nice thing about a device like this is that all you need in your living room is the TV. You won't have a full size PC sitting there attached to your TV via a cable. Much cleaner.
Zarathustra[H];1041562362 said:I had been eyeballing the Asus Chromebox though.You have to hack it to install an OS other than Chrome OS, but it doesn't look TOO difficult.
This doesn't mean anything.Yeah this is what I what I was wondering too. Half the performance of core M processors which makes me doubt...
Your numbers are pretty spot on I believe. Not that anyone ever sees the peak throughput, but yeah, N should be a lot higher than 40-54Mbps. I get around 100-120Mbps between floors on average on the desktop machine on my top floor. (using N)
Also, remember all of these data transfer rates are half-duplex, so you can cut those speeds in half, even in the best scenarios.
I have an Asus ChromeBox running win 8.1; the bios hack wasn't too hard (just be sure to undo the bios protect screw before trying to flash, or it does a partial flash and gets really weird).
But you might want to consider getting the HP Stream Mini instead, it's almost the same thing, but you don't have to hack the bios, and there's more storage; if you want more than 2gb ram, double check that the mini has a second slot, I know HP wasn't populating all the ram slots in their chromeboxes.
Yes, I used the script from here https://johnlewis.ie/custom-chromebook-firmware/rom-download/ I had to buy a new USB drive to run the windows installer from (it didn't like the drive i had with sufficient capacity, it would boot off my 32 MB drive though... but that wasn't very helpful for windows). In windows, audio over hdmi doesn't work on the Chromebox; it's probably fine in Linux, but you should double check. There's a page on the Kodi wiki about these guys too http://kodi.wiki/view/ChromeboxZarathustra[H];1041562560 said:Were you able to do the bios mod so you don't have to hit ctrl-y (or whatever keypress combo it was) to boot ever time?
Zarathustra[H];1041562560 said:Thanks for the suggestion.
Wow, that looks like something I might bring my lunch to work in
From a specs perspective, it hits the spot though.
I'm usually a function trumps form type of guy, but I'm not sure I want that blue tupperware under my TVThat's a little much...
I can get by with the 16GB of the Asus though. I mean, my current HTPC has a 120GB SSD in it (because that is what I had handy that I wasn't using at the time) but the base install of Ubuntu Linux 14.04 LTS, minus the packages I don't need, plus Kodi only uses about 5GB, and my mythtv backend stores all content on my NAS.
The "boring black box" design of the Chromebox, and the $20 lower pricetag appeals to me so much more, as long as the bios hack isn't too bad, and I don't have to keypress on every boot.
Duplex cookies are like the best kinds ever, but I agree that you need full duplex cookies so you can have both sides AND the creamy stuff inside all at once or they're probably not as fun.
mmmmm, half-duplex...
Gizmodo destroyed this thing saying "No, hell no":
http://gizmodo.com/intel-compute-stick-review-don-t-buy-it-1699377058
The bluetooth and wireless share the same chips, not normally a problem, but if you are 100% on wifi AND heavy bluetooth the BT lags heavily. Plus in order to use a wireless keyboard/mouse you have to use that 1 and only USB slot to fill up an adapter, anything else and you have to get a POWERED hub as non-powered hub doesn't put out enough juice.
I'll take the HP stream mini for $30 more and get a helluva lot better performance, upgrade ability, wired ports, and a ton more:
Ars on the Intel Stick:
http://arstechnica.com/gadgets/2015...a-full-pc-thats-tiny-in-size-and-performance/
Ars on the HP Mini
http://arstechnica.com/gadgets/2015...s-stream-and-pavilion-mini-desktops-reviewed/
