intel 975xbx2 sata help
neo01
hello to you i need help i have a intel d975xbx2 known as badaxe 2 in this motherboard have a 8 sata ports 4 black 3 blue and 1 red (for e-sata).
all 4 black sata ports are connected to hard drives
i want to connect another 2 hard drives to the blue sata connectors in this motherboard. the blue connectors and the red one are belong to The Marvell 88SE6145 controller
• RAID 0 - data striping
• RAID 1 - data mirroring
• RAID 0+1 (or RAID 10) - data striping and mirroring
• RAID 5 - distributed parity
now i dont want raid at all i want the hard drive work as non raid how do i do this? please help and by the way the motherboard support also as non raid like its says
NOTE
The Marvell 88SE6145 controller supports single drive non-RAID configurations as well
as RAID configurations.
BIOS Version 1846 (never update befor).
It's only going to set them up as RAID if you enter the Marvell SATA controller configuration on bootup and manually define an array. You should be perfectly fine - just plug them in and you're good to go!
are you sure its heard too simple can you be more specific like when i connect the hard drive and its recognized by the marvell? thanks for the help
You would need to manually configure the controller to use RAID. If you just plug all the drives in and don't set up a RAID, they'll act like normal single drives. Like Wompa164 said, just plug them in and you should be all set.
Make sure your Marvell controller is enabled in bios and has a proper driver for Windows also. You might need to go into Computer Management and enable the drives also if they are brand new.
ok i try this but i remember the last time i connect the hard drive to marvell the drives was recognized but the only option was to press ctrl m to enter the marvell config. do you have the same motherboard like me?
the marvell in the bios recognized the hard drive but in the windows not shown even in the manage not shown i told you its not so simple please help any ideas? if i update the bios it will solve the problem?
I'm not sure updating the bios is going to solve the problem. Is the marvell driver installed in Windows? Does your Device Manager have a ! by the marvell controller?
why should i install drivers i dont want to use a raid mode everyone told me to just plug and play its not easy at all i work for this about 2 hours
The drivers are so the OS will recognize the drive controller. It has nothing to do with RAID.
i also install the drivers but nothing very hard this marvell thing i read about 5 houres in forums that a lot of people did not succseful to config the marvell this is a real mystorie i think the best way is if someone in this forum have the intel d975xbx2 konwn as badaxe 2 guide me step by step how to configure this 4 ports sata marvell to non raid recognized hard drive thank you very much.
Make sure you have the drivers for the Marvell controller installed. You need them even if you are not using RAID. You also have to go to the bios setup screen and disable 'Boot to optical device'. I believe this selection is under the 'Boot' heading in the bios setup screen.
you know if there is a way to connect my 2 optical sata drives to the marvell controller (blue ports) and be recognized in windows and can be bootable in bios?
note
i dont have the latest bios update 2838 is this version solved problem with the marvell controller (for exemple recognized the hardware in windows hard drive optical drives)?
note
Honestly, I have not tried using any optical drives on the Marvell controller.
Are you using all of the Intel (black) ports?
Maybe put the optical on the Intel and see if it will let you boot from it.
Sorry- I really didn't do too much with the Marvell controller, other than connecting a backup hard drive to it.
Think of it like this. You are currently using the 4 ports which I assume are handled by the intel controller (southbridge). The blue ports are handled by the Marvell controller. These are two seperate controllers. So when you hook up drives to the blue ports on your board just make sure that the controller is enabled in your bios. You should have an option in the bios for the controller to enable raid. Leave it set as IDE and then exit and reboot. Oh I make sure that you have your drives installed before doing this okay. You will need a driver for the controller once you get into windows. Because the controller will be recognized but windows will not have a driver for it. Install the driver and reboot. Once back into windows double check in device manager that all is well with the controller and then go into the control panel and open up Computer Management/Disk drives and create and format each drive accordingly.
i have 4 hard drive connected to the intel controller
what i want is just to connect my 2 dvd sata drives to the marvell controller so even if its a sata dvd i need to install drivers to marvell ?
in the bios did you set the dvd's to be read as ide devices?
I do not understand what you mean. It would help if you used proper English.
ok i install the drivers (the latest) for the marvell controller. now there are 2 optiones
1.creat logical drive
2.creat physical drive
what to do?
note
dont want any raid at all
in the marvell controller i plug a 1 hard drive of 250gb and i want it to work like the others as non raid.
You shouldn't have to "create" anything. Since you've now got the drivers installed in Windows, you should be able to connect the drive to the Marvell ports, boot up, and see the drive in the OS.
You shouldn't have to "create" anything. Since you've now got the drivers installed in Windows, you should be able to connect the drive to the Marvell ports, boot up, and see the drive in the OS.[/QUOTE
thats waht i had in mind to but windows vista sp1 ultimate dont see the hard-drive and when i go to the manage- disk managment i dont see the hard drive also but in the bios of the marvell controller i see the hard drive detected (when i restart my computer)
the driver is a software of the marvell with option to creat logical or physical drive but i almost 100% think it about if i want to creat a raid mode which i dont want.
any ideas thank you.
