Hey Guys, just realized that I never did post this here.
I see a lot of people here using the SuperMicro X9SCM and X9SCL board on this forum. As many of you know this board contains one supported Intel 82574L NIC, as well as one Intel 82579LM NIC, which is NOT officially supported. Because its not supported, the included driver doesn't work with it at all. The issue basically is because VMWare uses OLD(1.2 something) driver source code to compile their e1000 driver.
Well, now you CAN use that NIC! I did a whole lot of work taking the latest driver and making all the same modifications that vmware does to their offical drivers to compile my own based on the(at the time) latest 1.3.10a source!
Get it HERE! http://www.vm-help.com/forum/viewtopic.php?p=11181#p11181
