Intel 82579LM and 82579V
Discussion in 'Virtualized Computing' started by Chilly, May 13, 2011.
  1. TeleFragger
    TeleFragger Gawd
    787
    Nov 10, 2005
    for me..
    first one had nothing..
    second one brought up couldnt load module
    third one nothing....
  2. TeleFragger
    TeleFragger Gawd
    787
    Nov 10, 2005
    had to install xp on one so here is the ID
    [​IMG]
  3. peetz
    peetz n00b
    43
    Sep 5, 2011
    The PCI ID 8086:1502 is already included in the simple.map file, but it looks like the driver does not work with this device.
    What messages are logged in vmkernel.log when you try to load the module with "vmkload_mod e1001e. Press Alt-F12 on the console to switch to the logging screen. You can scroll up and down there with the cursor keys.
    - Andreas
  4. sloncek
    sloncek n00b
    3
    Oct 9, 2011
  5. bluetrevian
    bluetrevian n00b
    3
    Sep 30, 2011
    Yep of course I downloaded BOTH .RAR files as instructed!! :D
    From what I've discovered... Windows XP (32-bit) is horrible at generating custom .ISO files from an OEM.tgz. Lesson learned.
    After much frustration and reading--I present to you--ESXi 4.1U1:
    ~ # esxcfg-nics -l
    Name PCI Driver Link Speed Duplex MAC Address MTU Description
    vmnic0 0000:00:19.00 e1000e Up 1000Mbps Full 44:37:e6:55:32:b0 1500 Intel 82579LM Gigabit Network Connection
    I am a happy admin! :p
  6. goofyhsk
    goofyhsk n00b
    12
    Jun 24, 2010
    Just want to confirm Chilly and/or Peetz,
    No one has successfully enabled these chips with 5.0 yet?
  7. TeleFragger
    TeleFragger Gawd
    787
    Nov 10, 2005
    worthless post
  8. danswartz
    danswartz 2[H]4U
    3,609
    Feb 25, 2011
    That card doesn't use the 82579LM chipset, does it?
  9. Jesse B
    Jesse B [H]ard|Gawd
    1,631
    May 30, 2010
  10. danswartz
    danswartz 2[H]4U
    3,609
    Feb 25, 2011
    Not a real useful comment then :(
  11. TeleFragger
    TeleFragger Gawd
    787
    Nov 10, 2005
    updated my post.. thanks :p
  12. danswartz
    danswartz 2[H]4U
    3,609
    Feb 25, 2011
    Sorry didn't mean to be snippy...
  13. RickM
    RickM n00b
    1
    Oct 13, 2011
    Hi Chilly,
    I have a new system, HP rp5800, with an Intel 82579LM Gigabit Network adapter. I tried the ESXi-Customizer along with your 2 oem files..... and as I read in other posts that didn't work.
    So, it will be nice when you have so graciously taken the time to create new ones. Thanks ahead of time!
    - RickM :)
  14. TeleFragger
    TeleFragger Gawd
    787
    Nov 10, 2005
    i know.. no biggie.. im a thick skinned person... so it didnt bother me.. but you did comment correctly... my post was just that i had to put a different nic in to get it to work...
  15. shortkud
    shortkud [H]Lite
    109
    Dec 12, 2006
    This is not the actual VDDK, the tar.gz just contains the open source archives VMWare uses and is required by the GPL or their licenses to provide downloads for.
    I'm interested in getting a driver for the Intel 82579LM working on ESXi 5.0, preferably over PXE install.
    I'm researching how to do this and can provide any help needed to Chilly/Petez. I have plenty of systems we can test on if needed.
  16. peetz
    peetz n00b
    43
    Sep 5, 2011
    All,
    I think that it is not possible (or at least very difficult) to built an ESXi 5.0 compatible device driver without access to the open source code of the drivers that are shipped by VMware, and - more important - the modifications that were made to it by VMware
    (Chilly: If you do not agree, and maybe have already made progress here, then please let us know).
    As of today, VMware has not made the Open Source code of ESXi 5.0 available for public download. However, the GPL obliges them to provide access to the Open source code they used and the modifications they made to it.
    Providing access does not necessarily mean making it available for public download ...
    On the ESXi 5.0 install media there is a text file VMWARE-ESX-BASE-OSL.txt with instructions on how to get access to the source code (at the end of the text).
    I have now followed these instructions and sent a request to info@vmware.com.
    I'm looking forward to the answer ... and will let you know how this works out.
    - Andreas
  17. unclerunkle
    unclerunkle [H]Lite
    94
    Nov 9, 2010
    Sounds good Andreas, keep us informed.
  18. shortkud
    shortkud [H]Lite
    109
    Dec 12, 2006
  19. peetz
    peetz n00b
    43
    Sep 5, 2011
    It does contain ESXi 5.0 with all drivers that have been updated by VMware since the release of ESXi 5.0. These updated drivers are available as separate downloads here:
    http://downloads.vmware.com/d/info/datacenter_cloud_infrastructure/vmware_vsphere/5_0#drivers_tools
    And, no, there is no updated version of the e1000e driver in there ...
  20. peetz
    peetz n00b
    43
    Sep 5, 2011
  21. sloncek
    sloncek n00b
    3
    Oct 9, 2011
  22. Chilly
    Chilly 2[H]4U
    2,054
    Oct 3, 2005
    http://hardforum.com/showpost.php?p=1037937845&postcount=8
    Your welcome to look into the code and do it yourself if you like. If you have any C programing skills I sure as hell won't refuse the help. :)
    The only useful thing I can say is this, reverse engineer the code changes by comparing VMware's driver code to the "official" open source code of the same version its derived from. This advice applies for any driver people are looking to add support to.
    In any case, I will post and update on my progress at the end of the weekend.
  23. halcyon
    halcyon Gawd
    719
    Mar 20, 2003
    Hey Chilly-
    Just following up to see if there was any new progress over the weekend.
    Thanks for your work!
    -David
  24. Chilly
    Chilly 2[H]4U
    2,054
    Oct 3, 2005
    First initial 82579LM custom driver compiled :D
    Currently testing driver, no clue if it works or not yet. Might require further changes need to be made. I will update as progress is made.
  25. halcyon
    halcyon Gawd
    719
    Mar 20, 2003
    Nice, good luck!
  26. Chilly
    Chilly 2[H]4U
    2,054
    Oct 3, 2005
    Code:
    login as: root
    Using keyboard-interactive authentication.
    Password:
    The time and date of this login have been sent to the system logs.
    VMware offers supported, powerful system administration tools.  Please
    see www.vmware.com/go/sysadmintools for details.
    The ESXi Shell can be disabled by an administrative user. See the
    vSphere Security documentation for more information.
    ~ # vmware -v
    VMware ESXi 5.0.0 build-469512
    ~ # vmware -l
    VMware ESXi 5.0.0 GA
    ~ # vmkload_mod e1001e
    Module e1001e loaded successfully
    :cool:
  27. peetz
    peetz n00b
    43
    Sep 5, 2011
  28. bluetrevian
    bluetrevian n00b
    3
    Sep 30, 2011
    Let us know if you need testers for this software! Been waiting for this one for a while as I want to get Win8 up on a VM. Hope you're doing swell!!
  29. wroopy
    wroopy n00b
    9
    Nov 4, 2011
    If needed I can also help you with testing.
  30. madmack31907
    madmack31907 n00b
    1
    Nov 9, 2011
    any update on driver for ESXI 5
  31. DirtyWilly
    DirtyWilly n00b
    9
    Nov 12, 2011
    Any luck with the Intel 82579LM NIC drivers for ESXi 5.0?
    I've been waiting for the oem.tgz drivers for the Intel 82579LM NIC as well. This is for a new system with no data so if you need a tester I'll be happy to help.
  32. sloncek
    sloncek n00b
    3
    Oct 9, 2011
    how much has the source code changed between VMware's version and intel's current one? Will is be sufficient to simply add the PCI ID of the 82579LM chip to the .map file?
  33. Chilly
    Chilly 2[H]4U
    2,054
    Oct 3, 2005
    Not that simple, the inbox driver in ESXi does not support the 82579 PHY at all. VMware's driver is based off an older driver.
    In any case, if my testing tonight goes well, I might be posting the first ESXi 5.0 version up tonight! :D
  34. DirtyWilly
    DirtyWilly n00b
    9
    Nov 12, 2011
    Woohoo!!! Gonna wear my F5 key out. GL. :)
  35. shortkud
    shortkud [H]Lite
    109
    Dec 12, 2006
    Chilly the oem.tgz that is linked in the OP should work with ESXi 4.1 and ESXi 4.1 Update 1 correct? Are there any instructions on how to use it with a PXE install?
    I do the PXE install via NFS with a kickstart to customize.
  36. unclerunkle
    unclerunkle [H]Lite
    94
    Nov 9, 2010
    Exciting! Thanks for all your hard work Chilly. Just in time for Thanksgiving break too :)
  37. Chilly
    Chilly 2[H]4U
    2,054
    Oct 3, 2005
    It will be up in 30 minutes or so, I'm just cleaning up the OEM.tgz file, and creating proper .map files.
    Now, just a few hints ahead of time, the OEM.tgz which I will be uploading, should be used only with ESXi 5.0 and injected using the ESXi 5.0 Customizer by Peetz. My OEM.tgz for 5.0 designed around his method currently.
  38. DirtyWilly
    DirtyWilly n00b
    9
    Nov 12, 2011
    Chilly, you are the man!
    Any issues so far?
  39. ripken204
    ripken204 [H]ard|Gawd
    1,427
    Aug 24, 2007
    so we need to use this?
    http://esxi-customizer.v-front.de/
    does this mean we need to reinstall esxi?
    i will probably try it out this weekend. i don't need both NICs working but it would be nice to have them just in case.
  40. Chilly
    Chilly 2[H]4U
    2,054
    Oct 3, 2005
    First release for ESXi 5.0, it may be buggy as hell, cause your system to crash, etc etc, so I provide it AS-IS, I take no responsibility for any damage, USE AT OWN RISK. This release is designed for use with Peetz ESXi Customizer ( http://esxi-customizer.v-front.de/ ).
    Let me know if you have any issues, if your device isn't detected or whatever comments you want to throw my way. :)
    Enjoy!
    http://dl.dropbox.com/u/27246203/E1001E.tgz
