- Feb 1, 2005
I have an older high end PSU from maybe 3 years ago that whenever I try to use it, it gives instant power to any motherboard I plug it into. Fans start spinning as soon as I flip the switch in the back. Both boards I tried it on are outside the case so there is no shorting taking place. I had this problem before, and I just turned the PSU off and unplugged it for a little while and plugged it back in and it worked. Now it doesn't even do that.
Any ideas how to fix this?
