Didn't think I had to create a thread for installing a fan, but here I am.
Current have the Antec 900 and decided to put the 120mm Fan on the side. Using an existing 120 from older computer. The fan only has a small 3 prong connection that I can't find in the new computer. Not sure what the 3 prong is called.
I also have the 780i EVGA MB. I thnk I see a male counter part to the 3 prong on the MB but can't be certain.
Question is, can I connect directly to the MB if I can't find a male side connection from my existing power supply? (corsair 750tx) Not sure if new 120's have different connections or not. Probably should just buy a new one.
