Installed Tuniq Tower...bad temps.
Riddlinkidstoner
Alright so after a long fight with the tuniq tower installation (I have a very cramped PC-60 Plus II...sucked to get that bastard in) I'm getting unusual temps with my overclock.
E6300 1.4v @ 3.1ghz 450x7
Speedfan = Core0 53 | Core1 54
TAT = 63/63
CoreTemp = 68/68
PCWizard/Gigabyte EasyTune5 = 52/53
I'm not sure what to believe...but I always assume the higher number. I guess I have to reseat it and try again :(
Wow none of those match as I would have thought they woud, I just compared those three on my DQ6 and easytune was the one that was way off. /shrug.
check your versions for coretemp and speedfan.
Major pain but perhaps taking the board out of the case will let you get a good mount on it.
That would be my first suggestion as well. It's too cramped in a case to be absolutely positive that you made good contact and have the heatsink seated correctly.
I'm more inclined to believe TAT, and with your voltage/speed, that looks about right assuming those are Orthos load temps. Want better temps? Lap that CPU and Tuniq, you might be surprised how much better they get.
Has to be a bad mount. My E6300 and tuniq tower @ 3.4 with 1.35v (actual) 1.4v (bios) and i get 58c both cores in tat 8 hours orthos
Alright after a few painstaking hours of reinstallation my load temps are now 43 w/ TAT :D
Definately was a damn bad mount :( poor CPU.
