installed DuOrb on HD4850 = blank screen
damole
I finally got round to installing the DuOrb on my HD4850 after running it with the stock cooler for a few weeks. It's the first time I've installed a aftermarket cooler but it seemed quite straight forward. My only query was the fact that the stock heatsink used to be attached to the chips and resistors at the right side of the board and whether I should use thernal paste on the vram heatsinks (I didn't).
Anyway after it was all done I put it back in my machine and turned it on, the bios screen displayed as usual but after a few seconds I got a blank screen. This happened whether I entered setup or let it continue booting to windows. I tried another monitor, same thing and also tried disconnecting the power lead for the cooler to see if it was drawing too much power. I switched back to my old 8600GT and it works fine.
Any ideas?
could not be attached right , or not making full contact with GPU Core?
try putting back stock cooling , yes i know its a hassle... an see if she works
So I'm both surprised and happy, I put the stock cooler back and now it works fine. Is it the case that the card is shutting down after less than 10 seconds, nothing felt particularly hot. I bought some more thermal paste yesterday so I will try again later today. For now I'm just happy that the card is ok so thanks for the tip.
--damole
my buddy has the thermaltake duo orb , he said it was a tricky install it took him two tries aswell
easiest thing to do is , clean off the GPU Core & apply a dab of thermal paste an put the cooler down on it an make sure its making full contact , an if it is place it back down an screw it on there
yea be grateful they do this.. (remember the the first Socket A AMDs that would flash fry if no HSF was on when booted)
my X1900XTX did the same thing when i put on my HR03... it was raised up every so slightly and the GPU would shut down after about 30 seconds at POST..
OK, I guess this is why it says noob next to my profile name. I temporarily attached the new cooler and could see that not much contact was being made which was the point when I realised the 2nd set of bolts provided had a shorter clearance and when using these the sink was snugly contacting the gpu surface. I fired it up again and it worked a treat, I now see temps between 39-43 degs instead of 79 degs. Now that's cool!
Thanks again.
--damole
Thats good to here damole , thats why the forum is here - people helping people!
glad to see it worked out for yah , an yea those are about right temps! , now give her a bit of OC =) an enjoy
