installation help...
amit77
im trying to install MS publisher at my schools bunkass old computer...everything starts up fine but after it goes thru its windows installer i get an error saying that a DLL file is missing for windows installer and that ms publisher installation will end prematurly..it won't tell me the DLL file that is missing...and i tried to update windows installer to 2.0 but i still get the same error....its windows 95 btw...any help? is there anyway i can compress the already installed one off my computer and just take it up there..cause i just cant get it to install...
error 1723 btw...
yes but its my teachers computer and of course she needs alot of stuff on it and no burner or anything is present...
i never thought about an update tho...
Exactly what is the error message it is giving? It sounds similar to a problem i was having when installing Office XP to a 98 awhile ago. Which i was able to solve, by deleting(but backing up first) the MSI.dll in c:\windows\system32. Since it was apparently an older version. The installer would then install its own to replace it. It installed fine after that.
Partition it so that it can dual boot
She could use the files from 95, and have the (errr) stability of 2k
