Install programs to external drive?
Discussion in 'SSDs & Data Storage' started by Uncle Humjaba, Aug 10, 2011.
  1. Uncle Humjaba
    Uncle Humjaba Limp Gawd
    408
    May 6, 2006
    Recently I installed a 96GB SSD into my laptop (the drive was free), replacing the 500gb HDD that was in it. I was wondering if USB 3.0 can provide enough throughput to allow a 7200rpm notebook drive to operate at full speed? I don't mind carrying a small ext hard drive with me for times when I want to use certain games or programs that I don't use daily, but I don't want to spend hours waiting for them to load either.
    Basically, is USB 3.0 still a bottleneck? If so, how much?
    Thanks
  2. gjs278
    gjs278 Gawd
    711
    Feb 22, 2011
    theoretically it shouldn't be a bottleneck... but you never know with usb
    I'm getting a rosewill usb 3.0 enclosure tomorrow. I'll try it out and let you know my results for a 7200 2tb drive from hitachi
  3. Uncle Humjaba
    408
    May 6, 2006
  4. s0rce
    s0rce Limp Gawd
    495
    Jan 17, 2011
    I think USB has more CPU overhead than SATA so you might notice a difference.
  5. gjs278
    gjs278 Gawd
    711
    Feb 22, 2011
    okay, I got the enclosure.
    this is very important if your motherboard is not very new but still has usb 3.0 and uses the NEC host. update your firmware.
    holy shit I wasted so much time fiddling with this thing to make it not hang in linux under the xhci driver. it would read fine, but as soon as you go to write, it completely dropped the drive.
    anyways, it's this enclosure http://www.newegg.com/Product/Product.aspx?Item=N82E16817182223 *fixed link*
    I'm writing at 115mb/s burst, about 70-80 average average. with this thing while doing a backup of my raid1. it's really good once you get it working.
    if your firmware for your NEC host is out of date (oh yeah it is), go to http://www.techpowerup.com/forums/showthread.php?t=130099 and grab the last link in the first post. you'll need it. you have to do it in windows, and you can check the firmware version in the program that comes with your mobo cd for the usb 3.0 driver.
    I'd say it's really good and it's definitely not bottlenecking my 7200 drive.
  6. TheLastBoyscout
    TheLastBoyscout Limp Gawd
    142
    Feb 13, 2011
    Do you have it connected via eSATA? The enclosure that you linked, is NOT a 3.0 one (hence the price). Newegg sometimes makes mistakes, but even Rosewill does only talk about USB 2.0: http://www.rosewill.com/products/1366/productDetail.htm
    -TLB
  7. gjs278
    gjs278 Gawd
    711
    Feb 22, 2011
    derp. I linked the wrong one. rosewill and their enclosures that all look the same.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817182223 this is mine. no promo, and yes, using the usb 3.0 sorry about that
  8. wkearney99
    wkearney99 Limp Gawd
    365
    Sep 8, 2010
    What model laptop? If you've got an optical drive in a bay you could use that for the hard drive instead.
