Ok, so I'm upgrading one and using the leftover parts on another system with some older parts that may work. This is where I need your input.
My current main build is:
Intel Core 2 Duo E6750
GIGABYTE GA-P35-DS3P
8800 GTS 320MB
4 GB of DDR2 RAM
500 GB HDD
Corsiar 520HX
I plan to replace the CPU with a Q9400, possibly OC it in the future whenever I feel like it, and the case which is the Raidmax Smilodon Extreme. I want to replace the case with a quite one or one that isn't too loud. This current case is great, but 4 fans was louder than I thought(I was a newb back then). I'm looking for a quieter one that will do a good job. Anyone have any suggestions on a good case? Right now I'm looking at the COOLER MASTER Mystique.
Now, I want to take the E6750 and case to build the other system, but I need a new MOBO and RAM. Here are the parts that I plan to use for the other system.
C2D E6750
GIGABYTE GA-G31M-ES2L
2 GB of DDR2 RAM
7600GT video card
XCLIO XClio 450BL 450W
The other parts not mentioned isn't really important since this system will be used for basic stuff like internet, paint, and some games(not intensive games, something like "learn how to type" games and etc).
I would like your input on the MOBO and PSU that I have chosen. Will the second system run fine? I don't want to spend too much money on the second system.
Thanks for taking your time.
8800 GTS 320MB
4 GB of DDR2 RAM
500 GB HDD
Corsiar 520HX
C2D E6750
2 GB of DDR2 RAM
7600GT video card
