input needed for a workstation build
cmge
trying to help a colleague build a workstation and while i dont know much about building a workstation for these functions:
-rendering 2d/3d modelling
-running revit architecture and structure
-3ds max
-microstation
so he went to local computer store in toronto, canada and was given a quote for $2500+ for a complete system..
i7-4770
asus z87-a
asus vs247h-p 23.6"
thermaltake smart power 750w
corsair vengeance 32gb (4x8gb)
pny quadro k2000
win 8.1 x64
seagate 2tb hdd
asus drw-24f1st
cooler master k280 case
generic keyboard + mouse
while i agree with some parts there are some that are questionable..
any help or input would be greatly appreciated.
As part of sticky question #1, please let use know which programs are being used.
3ds max and revit as mentioned in OP
more details
2d/3d modelling using programs like 3ds max, microstation, revit
$1500 CDN
canada
cpu, mobo, vidcard
no parts being reused
6) Will you be overclocking?
mild
new build therefore new monitor 1920 x 1080
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
usb 3.0, sata 6gb/s
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
win 7 pro x64
Questions #4, #5 and #7 conflict one another. In question #4 you state that you only need a cpu, mobo and video card yet in question #5 you state that you aren't reusing anything. Even if you're running the machine naked it will still require a PSU at the least. Then when we get to question #7 you state that since this is a new build you'll need a new monitor yet question #4 doesn't state needing a new monitor.
my colleague already made up their mind in regards to the psu, ram, optical drive, keyboard + mouse, case, os, monitor
therefore the input that i require pertains to the cpu, mobo and vidcard specifically
Out of curiosity, what did your colleague choose for those parts?
Then how much of the budget is left after you've accounted for the PSU, ram, optical drive, keyboard + mouse, case, os, and monitor that your colleague chose?
Well that's nice, but that still doesn't mean you can't tell us. How do you expect me to recommend parts that are compatible with parts I know nothing about?
Not to mention are those parts part of the budget? If so, what's left over from that budget now?
