Inno3d - good card makers?
MorgothPl
I'm soon buying 2nd 280gtx, and well, there is like 100$ difference between cards of innovision and evga (currently have evga sc). I know that it's possible to SLI 2 different 280 brands, so I'm not wishing to overpay the 100$ - especially as no chance I need warranty longer then 2 years...
Now, anyone heard anything of the InnoVision, aka Inno3d cards? Andy good brand, or something like Palit, masters of exploding capacitors? :p
Inno3D's been around for a considerable time.
They just don't have the high level exposure that other brands do, and therefore you won't find much pro/con in relation to them. For $100 difference, I'd compare the specs to make sure all is kosher, and then buy. For $10 I'd say no, but for $100 I'd say you'd be throwing money away if you didn't at least consider it. If its a 1-3% difference in performance between brands (typical it seems) then I'd say its well worth that savings.
I have an Inno3D 8800GT, for the simple reason:
Most cards that have a NVIDIA GPU comes from the same factory and danish laws give me ample of warranty.
