Infared Receiver help
evolved_st8
Ok. So i got a problem. When i power off my xbox using its DVD remote. MY PC GOES INTO STANDBY. Y?!?!?! How the hell do i stop it from receiving signals from EVERYTHING IN THE ROOM?!?!?!?! Any suggestions? Is there a program to train it? Or to stop it? Any help would be GREATLY appreciated
WTF?
Thats weird. Never heard of anything like that happening. Have you tried removing any piece pf hardware on your PC that can receive infrared signals?
And what do you mean by "everything in the room"? Do you mean other remotes put the PC to sleep too?
Also, please list the specs of EVERYTHING in your PC.
Yes. My Media center infared receiver for my PC is the only thing that receives signals. It will pickup signals from ANY remote but will power off when i hit the power button on either my media center remote, my Xbox 360 remote, or my Directv remote which is programmed for my X360
Specs are
Athlon FX 62
2 GB Crucial Ballistix DDR2 800
Ati Radeon X1950XT
Asus M2r32-MVP
1TB 2 500 GB Maxtor Sata 2 (Raid 1)
Creative X-Fi Xtreme Gamer Fatility edition
700W Power supply
Ageia Physx By BFG
Z-Board Gaming Keyboard
Logitech G7 Cordless
Lightscribe DVD-RW
Well that means that the same signal for powering down your 360 is the same as the Pc's standby feature.
Unfortunately I'm not too knowledgeable about infrared remote and remote programming. Try posting this in the HTPC subforum. I know the guys there use remotes to power down their PCs.
