Gaming. I'm mainly building the PC to run the old republic at a decent ramerate, my laptop can't keep up. I may also use this PC in the future as an HTPC.
I'm going to start low at $500. I can probably go up to $600+ but I want to try to keep it somewhat low.
USA -> south New Jersey
Mobo, CPU, RAM, Graphics, Harddrive, DVD Drive, PSU, and hopefully a small Case.
Nothing. I'm trying to do this from scratch
6) Will you be overclocking?
No
I currently have no monitor, so I will have to buy one of them as well. That is not included in the budget because I may purchase a new TV soon.
After christmas
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
No clue what features I should even look for at this point. I'm thinking one that can support a quad core processor so if I want to I can upgrade the processor in the future
I have Windows 7. Can I use my license on more than one computer without issue?
Personally, I'm looking for a machine that will be able to run Star Wars TOR well, maybe turn into an HTPC. Other than that, I'm not really sure what else I would do with it other than web browsing. Might possibly use it for some audio programs as well, although I can dedicate my Laptop to that.
I'm seriously in the black about what is good now a days. The last time i even looked into building my own computer was over 5 years ago, and things have changes SO much since then.
I realize everyone will have a different opinion, ideally I think I want to stick with something that will be stable. From what I can tell quad core is now the way to go, since dual core is getting obsolete? Hoping I can swing this with my budget.
Thanks for any and all help everyone! I really appreciate any guidance.
No
After christmas
