Indentifying a dead mobo?
nuggetz
Since my other post went unanswered in a time of need, I'm going to try again here. Anyway, if anyone is still with me I'm wondering if there's a sure sign of mobo death. I'm still in mourning over my loss of this brand new board so I'd like to get some closure from someone who has experienced this before :)
While installing a FD, one of the power connectors must have touched the 1394 pins on the mobo. I forgot to turn off the PS while doing this. Anyway, the mobo I have is an A8N-SLI and the standyby light is still green but it the PC wont turn on. I tried resetting the bios, by removing the battery, switching the jumper back and forth, and leaving the power unplugged overnight and still no go this morning.
Whats getting me is that stupid green led. If it's dead, why would it still be on? I cant test since I only have one 24pin PSU. I hope something else isn't fried. Anyone ever fry their processor or memory like this? I hope it's just the board but I still cant say for sure. Would the MOBO behave like this if it was the processor? I would expect it to try and post, beep and fail, but I get nothing. Power is definitly coming out the Antec Neo PSU. Any help would be appreciated.
Your power switch is connected to the mobo in the right place isn't it ;).
Yes it is.,
The only thing I was messing with was the power connector and a floppy drive which I had external to the open case. What's funny is the first one broke when it was clearly working the day before. Like I said, when I tried to use the floppy for the raid drivers the first time, I missed the message during boot that stated that the floppy drive was bad. When I disconnected the power from the bad drive and tried to connect it to new drive is when I saw the led's on the fans go on. The PC was in a soft power state. That's when things stopped working. I had no reason to believe that simply plugging in the power to the floppy caused the problem, I noticed that the open molex connector was near one set of pins on the mobo so I assumed that caused it. Not sure if modular cable I used to plug into my PS was incorrect, but it looked and fit like a floppy power connection.
Anyway, last night I took the board out of the case and set it on a newspaper and connected the bare minimum, mem, cpu, ata connection, and vid card. I also had the speaker pins connected to hear any beeps. What's funny is that the power led on the case remains on when I turn on the PSU but that's the extent of it. Needless to say nothing happened. I inspected the mobo and couldn't find any signs of damage. Took the heatsink off the cpu and it looked good too.
I want to test my PSU tonight just for giggles. Which pins on the 24pin connector should I be touching with my multimeter? Anything else I should test and how? Maybe some connections on the board while the PS is on? Anyone think it could be the PSU?
If you want to see if your mobo is dead, follow these steps:
1. take the mobo out of the case, use something like the mobo's box or something to place it, connect everything as it was in the case and try to turn it on, this is because you may be shorting something with the screws in the case.
2. if it doesn't boot, try removing the video card and booting with the integrated video.
3. if it is still not booting try booting with only one dimm, and try booting with the ram in different slots.
4. turn on the mobo without any ram, it should beep, if it doesn't beep it is almost sure it's dead.
5. turn it on without nothing connected, no ide, no fd, no ram, even no cpu, only psu ;) , and if it doesn't give you any beep, it is sure it is dead... :(
(be sure to connect the pc speaker to the board so you don't get a wrong diagnostic!!! :D )
Thanks for the reply man, I think it's really dead. I kinda liked the board but since I'm new, can someone tell me if there's a better board in this price range that will yield a better overclock? Im not sure if this board allows me to mess with the memory timings as worded in Eclipses guide, unless he was using different terminology.
my dfi-lp ultra d just pulled the exact same stunt. one day it would not power up. it just gives one light on the led. no fans or anything.
tried all the tricks to get it back up-- changed the ram (i've got dozens of sticks)
no-go
swapped the psu, re-seated the psu, clear coms-- removed changed the battery --ect ect-- finally sent it back for rma.
pulled all the other components and put them in my old a8n-sli deluxe and everything worked fine -- only thing i can think of is it must be some kind of nf4 sudden death syndrome ?
the DFI ran like a top--but one day wouldn't power on. no symptoms or instability--kinda reminds me of the northwood sudden death from a few years back--lol :eek:
