Qft.Met-AL said:Yep, you will be ok in that respect, but overclocking the AGP bus is pretty much useless.
hfc said:overclocking the agp bus by about 4MHz is enough to cause the videocard to have problems (windows crash due to video driver).
that's my experience anyway.
one would always want to lock the agp clock down, but even this is not possible (not precise enough) on motherboards with lock enabled.
i don't think many motherboards are physically capable of actually locking the agp/pci clock, since it is run off the same clock ic that the fsb uses. probably just uses some software trick which is inaccurate (4MHz agp increase with 32MHz fsb increase on my p4p800 which is already not stable enough to run games). if the agp was properly locked down, i could oc the cpu more.
if anyone knows the reason for the 'agp lock fallacy' i'd like to hear about it.
Un4given said:That's not true. The NV chipsets have generated the AGP/PCI bus clocks separate of the FSB clock generator since NF2. However, the AGP and PCI bus clocks are generated from the same source, so while it is possible to up the FSB and not affect the AGP/PCI bus clocks, raising the AGP bus clock will take the PCI bus along with it.
Met-AL said:Thats what I thought was the case, that AGP and PCI are together, but seperate from the FSB.
With the NF2, that was a BIG feature to have, to be able to crank up the FSB, but not to overclock the AGP. I thought it was a feature that was supposed to be on the NF1 boards also, but I may be wrong.
hfc said:oh, ok, i thought there had to be a proper hardware implementation. i'm pretty sure my P4P800 (i865) doesn't have a separate generator though which sucks.
Un4given said:I don't really know anything about the NF1 series boards. Quite honestly, VIA still had the better chipset at that point.
