So after everyone's expert opinions about upgrading my old box in a previous thread, I decided that I'm going to build a new one (my frist build).
After reading a bunch of threads on these forums about componnets, I'm considering the following build that will hopefully give me the a good price/performance ratio. I'd like some advice as to what needs to be changed/upgraded/downgraded.
Ideal Build: NewEgg Link
Case: Cooler Master Cosmos 1000-RC
PSU: PC Power and Cooling S75QB
Motherboard: Asus P5Q Deluxe
CPU: Core 2 Quad Q9450
GPU: 2X Asus Radeon HD 4850
Ram: 2x2GB Corsair Dominator
HDD: 2X WD Caviar 640GB (Raid 1)
Sound: Creative SB X-fi xtreme gamer
Drives: Lite-on Blue-Ray ROM + LG DVD+/- RW
Cooler: Zalman CNPS9700
Total: $1957 (more like $1800 after rebates)
I could definitely spring for the above if it would be worth it. However, I'd like to spend less if possible, and this may be more power than I need. Could I get better price/performance from a $1000 build with a Q6600, single HD 4850, a cheaper case, non-crossfire mobo, cheaper 800 RAM a single 640GB hard drive, & 500W PSU? That would save about $800 when it's all said and done. I was messing around with configurations but I'm not sure which components should be downgraded. I can post my in-progress ~$1000 build if you'd like.
Also, this is my first build so is there anything else I need to order with this stuff? Do I need thermal paste? SATA cables? Static mat?
Notes:
1.) I won't be ordering for 3-4 weeks, so keep that in mind.
2.) I hook this to my 37" 1080P Westinghouse HDTV, and I like playing games at 1920x1080. (Do I need to 2x 4580's to do this effectively?)
3.) I'm more of the Oblivion/Bioshock/RTS/RPG/MMO type of gamer rather than an FPS gamer.
4.) While I do want gaming performance, I'll spend just as much time in Photoshop, watching blue-ray movies, and doing other productivity tasks.
5.) I don't plan on over-clocking right away but may in the future.
6.) PC will stay on most nights overnight, so stability is key.
Thank you so much. I really appreciate the help. If someone wants to suggest an entirely different build that's cheaper but still suits my needs I'm totally open to that.
Notes:
