Imation Unveils Paperclip-Sized USB Drive
Terry Olaes
I Used to be the [H] News Guy
Imation Corp. showed off the Atom Flash Drive, a USB drive that is 1.5” long and no larger than a paperclip. It weighs in at less than one ounce and can store up to 8GB of data. It’s also compatible with Vista’s ReadyBoost technology. Pic in the link above.
Chip sizes are compared to fingernails, MP3 players to decks of cards, asteriods to VW Beetles and now USB drives to paperclips. Who wants to invent a unit to compare to marshmallows?
thats a fucking big paperclip!
The dimentions of the USB stick (in a couple of dimentions) has already been fixed due to the USB port AND a std paperclip is alot smaller then that
Haha, I just had a mad thought.
If they can get a USB memory stick to fit completely inside the connector part of the USB plug, one could be plugged into a PC and fit flush to the surface.
Then stick a hologram of a USB slot on the rear end of the memory stick and it would look like nothing was plugged in.
correct me if I'm wrong but haven't we had drives that small for a while now? I had a pqi flash drive that was as small as that 3 years ago.
Me too, I have a tiny USB memory stick that has no metal slot parts just a bit of plastic with metal contacts on one side
Its tiny.
The smallest USB flash drives I've seen are the SD cards with a built in reader: http://www.engadget.com/2005/01/06/sandisk-ces-sd-card-with-built-in-usb-adapter/ There's a couple of other companies that make similar concept types.
Sony Micro Vault Tiny drives are also smaller than the Imation drive: http://www.engadget.com/2006/07/12/sonys-micro-vault-tiny-now-shipping-in-the-us/ These Ultra drives might be the smallest i've seen: http://www.ultraproducts.com/popupWin.php?noImg=10&sku=ULT40148&img_num=5
Who cares?
I mean, we could make these things as small as we wanted now.
Same thing with items like Micro SD.... You make them too small, it gets a ton easier to lose them.
At least in the Micro SD to SD example here (because those are both standard sizes we all know)... Quite honestly, SD is small enough to be as compact I need it. Why do I want some tiny Micro SD card to fumble around with???
Memory cards you leave in the camera 90% of the time, so that may not be a big issue.
But USB drives are made to take with you. Why make it so small???
I literally like the term "thumb drive". Needs to be no smaller than a thumb, easy to stick in the slot and easy to yank out.
Of course it could just be me, but those whole "make things as small as we can" has its usability limits.
Who cares?
Yep, much smaller.
I already have a easy time losing thumb drives, last thing i need is it to be easier to lose.
My OCZ Roadster 1 gig thumb drive is already somewhat that small. AND it fits on a keyring loop.
Exactly. The smaller and more capacity these flash chips get, the better our mobile devices (and other things) will get.
I didn't say they have applications. Putting them inside or embeded where you never have to mess with it is an entirely different function than something DESIGNED to be portable and handled.
Mine is smaller then urs :rolleyes: ummmm... yea...
I got this thing about 6months ago to evade security at work. (No storage of data of any kind is permitted... digital or paper) It's only 2GB but after removing the outer casing its just a little black rectangle. Easy to hide in your clothing or shoes or wherever. With the plastic case removed it measures to:
17/32 inches wide
13.5mm wide
7/8 inches long
22.23mm long
~2/32 - 3/32 inches thick
~1.6mm - 2.4mm thick
Here it is on ye olde egg
http://www.newegg.com/Product/Product.aspx?Item=N82E16820141250
I perfer larger USB thumb drives.
I like them slightly larger, but not as big as some of the ones I've seen from time to time. The Lexar Jumpdrive (the slim silver one), IMHO, was the perfect size and thickness for a thumbdrive. Shame Lexar doesn't use that shell/shape anymore for their current ones.
My favorite kind is the one that has a retractable interface so that I don't need a cap. I'm forever losing the caps to my USB drives.
I Dont really care what it looks like as long as it doesn't break in my pocket or get lost easy... I usually carry around a 3.5' enclosure with the power brick (sarcasm)
17/32 inches wide
13.5mm wide
7/8 inches long
22.23mm long
Damn terriorist spy. Get off this forum.
