imac, 21.5 or 27?
21.5, 27 or other size?
  • 21.5
    Votes: 4 12.9%
  • 27
    Votes: 25 80.6%
  • 24/17 another size?
    Votes: 3 9.7%
  • Total voters
    31
I voted "another size" as my imac is a 13" MBP hooked up to a 22" Dell monitor.
I have a 24" iMac... I think the screen in the 27" is nice, but it does depend on what you'll do with it. The 27" iMac is pretty massive so if you have it in a living room (etc) it will dominate pretty badly. Also if all you are doing is surfing the web, it's too big.
That said, the 27 height is the same is my 24, it's just a bit wider. I think the 27 is generally better value for money.
Any way you go I'd wait for the next refresh.
27.
You're not going to be able to upgrade it in the future so if you can, get the bigger display now.
27" Not only does it use one of the better 27" IPS panels out there, it's mDP can be used as an input, allowing you to use the monitor for another computer :) Other iMac's don't have this option.
Didn't know this, that's cool.
27". Fast machine, gorgeous display, and it doubles as a display for my gaming PC. It is pretty great.
Hmmm.....tempting. Do you use a KVM to switch keyboard/mouse/speakers over to the PC?
I do not, I have two sets of mice and keyboards that I use with my computers.
I have a wireless Apple keyboard and a wired Apple keyboard (this is stowed away on the iMac base until I need the extra function keys and the numpad) on the iMac, and a Steelseries 6Gv2 for my PC. For mice, a Steelseries Xai on my PC, and a Razer Deathadder on my Mac because Razer's OS X drivers are really good. For sound I use the internal speakers with the iMac and a small B&W stereo pair plugged into my PC.
Using the wireless keyboard makes the space work out just fine. Its even fine with the wired keyboard, but the wireless makes it so easy. I also have a second 24"monitor which is mainly used on my PC, but I can also use it as a second monitor for my iMac. I kind of stopped doing it though because 27" is enough for me for Final Cut now. A second display was a necessity back when I had a 24" iMac, but now not so much with the 16:9 and its high resolution.
A KVM would be nice, but I'm really happy with the setup since it allows me to use both machines at once if I want to (ie - rendering on one machine while I putz around on the other).
In any case, it is a glorious PC display. :)
Makes sense.
How do you switch the display over to the PC and then back to the imac?
I'm just waiting on the refresh to make a purchase. Already got wife approval.
Makes sense.
Command+F2 on the keyboard connected to the iMac will switch video inputs.
Just make sure that your video card has DisplayPort output. It comes standard in all new ATI cards, and it comes in a few NVIDIA cards like the EVGA GTX 570 HD. If that isn't an option, you need to use an active Dual-Link DVI to MiniDP adapter. I have the Atlona AT-DP400 to output from my GTX 460 since that only has DVI output. I got it for around $130 from Amazon last year.
