I'm a PC building n00b, how does this setup look?
vondozier
My whole PC life I've been stuck with cheap eMachines, and I figured now is the time to step it up.
I have absolutely no experience with building PCs, and will probably try to find someone locally to help me out.
I've tallied some help and suggestions, and I just wanted to see if any of the experts here had any opinions on pieces I'm about to collect.
-VIDEOCARD-
8800 GT
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130303
-PROCESSOR-
Intel Core 2 Quad Q6600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
-MOBO-
ABIT IP35
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127030
-CASE-
Cooler Master RC-690-KKN1
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
-PSU-
Corsair 520HX
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139001
-RAM-
A-DATA 2gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
-DVD DRIVE-
Samsung
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151153
-HD-
Western Digital
http://www.newegg.com/Product/Product.asp?Item=N82E16822136098
-OS-
Vista 32bit Home Premium
http://www.newegg.com/product/product.asp?item=N82E16832116202
-PASTE-
Scythe SCNJ-1100P
http://www.newegg.com/product/product.asp?item=N82E16835185038
http://www.jab-tech.com/Thermalright-LGA775-Bolt-Thru-Kit-pr-3605.html
Don't bother with the IDE DVD drive. Just spend the extra $15 for an SATA DVD burner:
Samsung SH-203B 20X DVD±R SATA DVD Burner - $32
Also, for $5 more, you can get an extra 70GB:
Western Digital WD3200AAJS 320GB 7200RPM SATA 3.0Gb/s Hard Drive - $75
Here's a side by side comparison of the Abit IP35 Pro and the Gigabyte GA-P35-DS3R:
http://www.newegg.com/Product/Produ...mpareItemList=N82E16813128050,N82E16813127030
Also, I recommend getting the Gigabyte GA-P35-DS3R if you're not doing or planning on heavy duty overclocking, don't need dual LAN NICs, or firewire:
Gigabyte GA-P35-DS3R Intel P35 Motherboard - $130
And here are couple of reviews for each mobo. Decide for yourself whether or not it's worth it for you:
Abit IP 35 Pro:
http://www.xbitlabs.com/articles/mainboards/display/abit-ip35-pro.html
http://www.overclockersclub.com/reviews/ip35__pro/
http://www.virtual-hideout.net/reviews/Abit_IP35_Pro_Off_Limits/index.shtml
http://enthusiast.hardocp.com/article.html?art=MTM4OCwxLCxoZW50aHVzaWFzdA==
http://www.legitreviews.com/article/513/1/
http://www.bit-tech.net/hardware/2007/06/01/gigabyte_ga-p35-ds3r/1
http://www.phoronix.com/scan.php?page=article&item=832&num=1
And now some questions for you:
- What size monitor do you have?
- What are you planning to do with this new PC?
- Are you planning to overclock?
- What's your budget?
1. 24" LG 246 through HDMI, which I keep on 1920x1200.
2. Heavy gaming, some Photoshop stuff
3. I have NO clue how to overclock. So I assume no, unless I can find a crash course step-by-step guide that I could understand.
3. I guess anything below $1,000 or so.
I agree with Danny... if you don't need the features of the IP35 Pro, drop down to something that fits your needs.
The E6750 can OC like crazy if you get a good cooler for it:
$35 - Scythe SCNJ-1100P Ninja Plus Rev.B CPU HSF (optional $7 Thermalright LGA775 Bolt-Thru-Kit; recommended if using w/ quadcore)
$45 - Tuniq Tower 120 CPU HSF
$46 - Thermalright Ultima 90 CPU HS + FBA09A12M - Z ($3)
$55 - Thermalright Ultra 120 eXtreme CPU HS + Scythe S-Flex Fan SFF21E ($15)
But since this is your first build, you may want to hold off on the OC'ing for the first few hours. :p The Thermalright Ultima90 is MUCH easier to install than the stock Intel HSF, btw, and keeps your CPU much cooler, too!
OC guide worth reading: http://hardforum.com/showthread.php?t=1198647
Crash course: bump the FSB to 400Mhz and Orthos test for 4 hours. If it fails, bump the voltage slightly higher than default.
something to think about...it might be worthwhile to splurge on a quad core for $85 more.
Q6600
good overclocker too.
Q6600
Don't get it from Newegg if you decide to splurge... get it from Clubit.com instead, since they guarantee a G0 stepping.
Q6600
That was my first choice, but I talked it over a few days ago with someone, and he recommended that the quad could be overkill, as he also mentioned hardly anything requires a quad so far anyway. I decided to just go with the duo.
After thinking about it, I might indeed just go Quad. Future proof myself a bit, I have the cash, so why not.
Vondy you have an OS? If not you might be a little over your buget.
P.S. you sure you wana go with a 8800gt. I think the GTS is faster someone correct me if i wrong. Then again it also adds to price and power consumption.
Or you could upgrade to a better quad within a year and sell your dual core to help offset the cost... thats what I plan on doing.
Nobody knows for sure yet... we're all waiting on the release and more reviews aside from the expreview posted in the vidcard subforum (according to which, it performs better than the GTS, lol).
Ok well I didn't know i figured it would be better because its got like what 640 mb ram owhell.
lol it does in my computers sake. With a amd althlon 3200+ 2gbs breaths life into the hole thing
I forgot all about an OS, lol. I might have an XP lying around.
What would you recommend, Vista or XP?
That PSU is 69.99 after MIR at zipzoomfly until the end of the month :).
I say Vista. From what I've read and heard so far, Vista isn't that bad these days. I think gaming performance is on par with XP now with the newer games. And plus, DX10 code paths only comes with Vista. So if you want to be able to use DX10 graphics, Vista is the only choice.
If you go to college, see if your college/uni offers Vista at discount. But here's a link to a pretty cheap copy of Vista:
Windows Vista Home Premium OEM - $100
Just about to start making my purchases on here, so I wanted to give it a little bump to see if there's any other tidbits or suggestions before I start buying the items.
Also, with the 8800gt, I've heard some suggestions of maybe getting a 600w PSU.
Opinions?
Opinions?
The 520W Corsair is more than enough for almost any single vidcard gaming setup. If you don't want the corsair, just make sure there are at least 26A available on the combined +12v rails -- NOT the arithmetic sum each +12V rail.
PSU FAQ: http://www.jonnyguru.net/forums/showthread.php?t=1036
PSU Suggestions:
http://forums.extremeoverclocking.com/showpost.php?p=1590883&postcount=193
http://www.jonnyguru.com/forums/showthread.php?t=1460
http://www.jonnyguru.com/forums/showthread.php?t=103
They're both of the same quality. Though if you want a bit more power, go with the 550VX. If you want modular cables, go with the 520HX.
