What I need:
I need a workstation I can edit photos on (yes, Photoshop) and some video. I would also like to be able to do some light gaming. I don't need to set any "godlike" 3DMark scores, but I would like to be able to play at a good resolution with a smooth frame rate. I also need this system to be as quite as possible without any crazy water cooling needs (my ears still hum from my older server case with 4 92mm fans in the front and 2 120mm fans in the back)
Specs I have gathered so far.
GIGABYTE GA-M61P-S3 AM2 NVIDIA GeForce 6100 ATX
EVGA 256-P2-N615-TX GeForce 7600GT 256MB 128-bit GDDR3 PCI Express x16 SLI
Thermaltake TR2 W0070RUC ATX 430W Power Supply
AMD Athlon 64 X2 4600+ Windsor 2.4GHz Socket AM2 65W Processor
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM SATA
LITE-ON 20X DVD±R DVD Burner
Total = <$500 shipped
I'd like to stay as close to $500 as possible but I also don't want something thats outdated. I'm not to worried about the display because I have a few monitors lying around I could use until my budget allows for a nice 19"+ LCD. Also, I have adecent case that will do for now, but as with the display, will get upgraded at a later time. HD space is fine for my needs as I have a WD 120GB traveldrive for my photo needs. Plus I'de rather setup a raid later on with a couple 160GB then have one huge 320gb single HDD.
So, hows does this look? Any recommendations? Is this system so dated that I might as well spend a few more $$ and get something newer?
I haven't posted here in a while and have read through the sticky and hope I have followed the guidelines for posting.
Thanks
Thanks
