ICH9R raid control
Is it possible to have 2 separate raid 1 setups on the same controller, as well as an optical drive?
The ICH9R ? sure no problem. Could even do 3 if you wanted. Only "gotcha" I have found is that raid 5 arrays are limited to 4 physical disks. Other than that it works the dream and is easy to setup. Boot, hit ctrl+I to go into drive setup and create whatever combination of arrays you want, have the raid driver installed in the OS or do the F6 pre-install with XP and away you go.
http://www.intel.com/design/chipsets/matrixstorage_sb.htm
I'm running 2 RAID 0's, a single HD, and an optical drive on the Intel ICH9R, so I'd say your options are open! :)
