I have an IC7-G and the fan on the NB is started rattling, anyone hear of remedy for this? Does this chipset run hot? Can I say screw the fan and let the heatsink do the work passively? I have a 2.4c @ 2.4 -No overclocking here
Hey abit northbridge fans are CRAP. If it last 3 months its a success to the abit clowns. My ic7 lasted 2 weeks, the new and improved replacement lasted 2 months. Mine works fine as a passive heatsink so I would not worry about it.
One of the hooks on the mobo for the NB heatsink/fan on my IC7-G popped off. The chipset ran for about a month without anything while the heatsink rested on top of my video card before I found out This is a non-OC'd system. I bought a Zalman heatsink and put it on with epoxy, been running fine for 2 years now.
Mine started going south after 5 months or so when I originally built my comp with the IC7-G; it then slowed down to like 3 RPM and started making a giant whirring sound.
I just unplugged it and have been running it that way for the past year and a half. I also overclock, and having it be a passively cooled heatsink hasn't hampered me.
I too built a box for a friend with an IS7 and sure enough, a month later the chipset fan starts going crazy and making terrible noises. Pretty sure he just unplugged it and runs it passive. Heck, nearly all 865/875 boards that I've seen have passive sinks. Unless you're overclocking a LOT it will be fine.
I have an IS-7 that I run overclocked to 250FSB and have the northbridge fan unplugged without any stability issues.
I also removed the foam square under the heatsink and replaced the white paste with Arctic Silver 5.
If you have good circulation in your case, you'll be ok. Run a benchmark or play a game then open the case and touch your finger to the sink, that will give you a good gauge on how well it's being cooled.
This has been an issue since the 875 boards were released like 2 years ago. I must be one of the VERY lucky ones because the NB fan on my IC7 still runs like normal today (still loud but thats because it goes so fast).
I unplugged the fan and all seems to be going well. I am glad this works because al alternate cooler/fan combo is more trouble than it is worth without serious mods. I put the TR-SLK-900u with a 92mm fan on the cpu-(everyone at the time said that was impossible). and that makes a cpu heatsink change or a ducting mod necessary, if passive cooling wasn't going to be successful
I have a brother who has an IC7-G, his fan lasted 3 months...
I bought an IC7-G, immediatly removed the heatsink and put on a water block so I never used it. I gave the heatsink to my brother to use on his IC7-G, lasted 2 months...
I bought an IS7 with the same heatsink, lasted 2 months.
I bought the ic7-g about 2 months after it was released and it (the fan) just now went out on me. It wasn't too far away until the "screw it-I got my moneys worth out if it" mark.
I too had a ic7g-max2 ... the first fan started doing that a little over 1 year after I got it.
thought the heatsink had come loose so...
took the heatsink off, cleaned it up and put the arctic silver hardener stuff on it and replaced it.
worked for a little while, then started rattling again.
just got a new version of it ( thought thats what crashed my comp...but it wasn't lol!) this new revised edition came with a shorter but wider heatsink... almost immediatly rattling on startup but not after that. im running it fine now.
everyonce in a while it will rattle at startup, but i don't have a problem with it.
