aaronearles
- Aug 31, 2006
Anyone have any experience with these? I have a project that relies on some software that only runs on AIX, so I've picked up an old P5-570 from work and may need some assistance getting started. It was a two node stack with 8 cores and 16GB total, I don't need the horsepower or assosciated heat at home so I've consolidated to a single node, four cores (8 threads), and moved over all 16GB of memory to the one chassis. I have the HMC as well, but I'd rather not run it if possible.
So far, I've been able to login to the ASMI web interface and FSP via telnet, and I'm taking a null-modem cable home today so I can see what I can get into with the serial console (and hopefully eliminate the HMC). It currently runs AIX 6.1, but I'd like to move over the mirrored drive from the second node and do RAID1 and perform a fresh install to get the feel for it. I do have plenty of linux experience, and some AIX experience on the host that replaced this one, but not in implementing it from scratch.
Each node had PCI-X FC HBAs connected to a DS4300 SAN, which I also got, but the plan is to re-utilize that for VM storage and export an NFS volume to AIX from my Synology, for volume storage.
