- Dec 17, 2007
Okay so besides stock coolers on CPU's, my only experience with higher end/third party CPU coolers is with the Hyper 212+ (have bought 3 of them for 3 separate PC's i liked them so much). But then again i have only had to cool a E5200 at 3.8Ghz and a Q9550 at 3.6Ghz... definitely not anywhere near pushing their thermal boundaries.
So, i will be getting a 3770K and reviews are saying they can OC stable to about 4.6-4.7ish, and if thats true i will probably OC mine to 4.5-4.6. However i have no clue what type of cooling to get. What are your [H]ard opinions on pho-watercoolers like the Corsair H70/H100 etc? Also, in general what is your recommendation(s) on what cooler you would get if you were buying a 3770K (or have a similar SB equivalent).
Only other things i know for sure, are that i am not going to go with real water cooling, and that the rig this new PC will be on is the HighSpeed PC Tech Bench ( http://www.highspeedpc.com/Merchant2/merchant.mv?Screen=CTGY&Category_Code=TopDeckXL )
(Though at some point its possible i will put the PC inside my empty HAF 932).
5-4-2012 NEW QUESTION: Current dilemma going through my head, is that if i get the Hyper 212 Evo ($35) and i want a second fan, i should just buy two new fans that will be super quiet. Those would be Noctua NF-P12's, which are $25 each. So in total the Hyper 212 Evo + 2x P12's would be $85.
Now there is something that i THINK is awesome but dont know for fact, and that is the Evo's unique thing about it is its heatpipes are in direct full contact with the CPU shield.
However i know the Noctua NH-D14 is $90 after rebate, the H80 is $90, and there are a few others in that price range. Are they all pretty equal in cooling performance?
