- Dec 17, 2007
So its not really a Versus persay. Currently i cant afford a Core i7 and new mobo, and im not even sure if i could i would, considering it seems like more and more new intel cpu's are coming out, and i think i have read that there arent a TON of i7/i5 boards out right now. I will probably be able to afford one by the time they change the stepping and voltage, aka when they come out with it re-done. (not sure the technical wording for what im trying to describe sorry.)
Anyways, so my gaming rig you see in my signature, that will be my standard computer once windows 7 comes out officially. The cpu is good, and im told its highly overclockable, and my mobo is a great overvclocking motherboard im told as well.
The best cpu you can get for my motherboard is the Q9650, but that is $350's and il pass. The next step down is the Q9550, which looks great and typically on [h]ere anyone with a great rig without core i7 has the Q9550. Im curious what your guys opinion is on it? If i got it, will it stand to time? Is it in the same ball park as the core i7?
Im planning on upgrading to it once the price drops more, iv noticed a popular store has it for $159.99 sometimes but you have to go to the store, and there isnt one in WA.
Lastly , if you know the answer to this it would be greatly appriciated: I notice the stepping on my Mobo website ( http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=3013#anchor_os ) that it takes for Q9550 is EO and C1, this guy http://www.hardforum.com/showthread.php?t=1459388 talks about there being a new stepping or new batch or something. (Maybe thats why they arent on tiger direct anymore?restocking) and do you think if i bought one of those new batch ones, would it be compatible with my mobo? Do those companies update their compatibility list often enough for me to know if its compatible or not?
Thanks guys and girls.
