no_control
- Jul 6, 2006
I have several builds lined up so is it better to keep it all in here or seperate thread for each build you tell me?
Any way here goes.
It needs to be a beast. Heavy CAD (mostly 2d but light 3d modeling as well) Some SU, KT, Light CS3 (pshop, premier), Crunching BD's down to MKV, and the usual web surfing
$1000 Taxed and shipped
3) Where do you live?
SoCal (yes MC & fry's is with driving distance)
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
case, cpu, ram, mobo, gpu, psu everything in the box except Opticals and HDDs
2x 128gb Falcon SSD's, 2x WD 640gb
6) Will you be overclocking?
Not likely but if I do it will be mild
37" 1080 HDTV
within 14 days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
RAID, SPDIF(Coax/optical), esata @ I/O would be nice, Gbit LAN,
10) Do you already have a legit and reusable/transferable OS key/license?
All software has already been purchased.
I was thinking something similar to my main rig in my sig would work. But wanted to get some fresh ideas from all of you. No MATX BTW I'm open to PII and C2Q
Thx
Any way here goes.
37" 1080 HDTV
within 14 days
Thx
