i7 hard-core build! Pure perfection!
djkilla
The deadline for my build is here! I'll be ordering the following and building within 1-2 weeks. For the pros and advance builders, is there anything you would recommend changing or am I set to go?
LIAN LI PC-8N Black Aluminum ATX Mid Tower (http://www.newegg.com/Product/Product.aspx?Item=N82E16811112245)
EVGA E758-TR Intel X58 ATX Intel Motherboard (http://www.newegg.com/Product/Product.aspx?Item=N82E16813188046)
Intel Core i7 920 Nehalem 2.66GHz 130W Quad-Core Processor (http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202)
Thermalright Ultra-120 eXtreme CPU Heatsink (http://www.frozencpu.com/products/8...66_RT_Rev_C_CPU_Heatsink_Socket_LGA_1366.html)
mushkin 12GB DDR3 1600 (PC3 12800) Desktop Memory (http://www.newegg.com/Product/Product.aspx?Item=N82E16820226050)
Intel X25-M 80GB SATA II MLC Internal Solid state disk (SSD) (http://www.newegg.com/Product/Product.aspx?Item=N82E16820167023)
Western Digital 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s Internal Hard Drive (http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319)
XFX Radeon HD 5870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready Video Card (http://www.newegg.com/Product/Product.aspx?Item=N82E16814150443)
AuzenTech AZT-FORTE X-Fi Forte 7.1 PCI Express Sound Card (http://www.newegg.com/Product/Product.aspx?Item=N82E16829156010)
Sony Optiarc Black 2MB Cache SATA DVD/CD Rewritable Drive (http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030)
CORSAIR 750TX 750W Power Supply (http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006)
**The CPU will be overclocked to 3.4-3.6
Looks good!
Keep the 640, it is better than the 1TB due to two platter design.
Power supply is overkill unless you plan on going crossfire later (and you would still be fine with less). The corsair 750 is a lot less money if you don't mind non-modular.
Though the WD6401AALS is (slightly) faster than the WD1001FALS, the speed difference isn't noticeable, especially compared to that of the X25-M. Get the WD1001FALS if you want/need the additional storage capacity.
What were you trying to link to? It's almost as if you're trying to prevent us from seeing where you plan on buying everything from.
Again, you don't need an 850-watt power supply for your setup. Get a cheaper 600-750 watt PSU. (Corsair is a good choice regardless of what you choose, but do you really need modular cables?)
If he's only planning on using the drive for storage/archiving, he can also consider the WD10EADS or even the WD15EADS. Great drives for those purposes.
Otherwise a great system.
Heh, I think its a censored site name.
Anyhow, what will you be doing with this system?
I like Lian Li cases alot but I dunno case seems a little light on cooling. My cheaper case (Lancool) has two 120 intake fans..and 1 120 rear..
Lancool is Lian Li's budget line, basically. A single 120mm intake + exhaust should be fine for moderate OC'ing of the Core i7/5. For higher OC's, you'll want better cooling.
I used tinyurl to create the links but they didn't show up correctly. I edited my post with the proper links so everyone can check the specs and get additional info now.
-D j K i l l a-
Encoding, decoding, transcoding a lot of video. Some VMs, photoshop and the occasional game or two.
-D j K i l l a-
You can save about $142 by going with three of these G.Skill RAM sets:
$86 - G.Skill Ripjaw Series F3-12800CL9D-4GBRL 2 x 2GB DDR3 1600 RAM
Gets you 12GB of RAM, $142 in savings, and lower voltages.
You may want to consider actually going for 6 gigs of ram instead of 12. Difficulties can crop up if you are using all of the slots and overclocking, and I can assure you once you hit 3.6 without breaking a sweat you will want to go further.
Just something to keep in mind.
Believe it or not, I'm going to try to stay in control and resist the urge to take it to the max overclocking. I have heard some people say 12 gigs could cause some trouble and a simple bump in the voltage for the ram might resolve any hic-ups. For the most part, according to what I've read in the overclocking forum, plenty of people have been able to easily reach anywhere from 3.2-3.6 overclock without even touching the voltage. That's exactly what I want to do and I hope doing it this way won't cause any trouble with 12 gigs of ram other than just a bump in voltage for the ram only to run smoothly at the rated speed and latency.
-D j K i l l a-
Made some adjustments to my first post and selected AuzenTech Forte PCI-E for quality sound and added Intel Pro network adapter which is compatible with drivers for Windows 7 64bit.
I'm still undecided about the power supply since many have suggested something smaller. Which Corsair power supply would be good for my build? I never plan on adding more than one video card but do plan in a year to upgrade the motherboard with the latest USB 3 and Sata 3.
I start building in a week! Thanks to everyone for the suggestions!
Corsair power supplys:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010090058 50001459&name=Corsair Memory
You really don't need a NIC, onboard works fine. Same with sound card unless you have some /very/ nice speakers.
Better to spend another $100-200 after getting rid of the excess and throw in another 5870.
I support the Sound Card choice, but the NIC... nope. I can understand it if you are going to dual boot this badboy using ESXi/ESX, but if not then the hardware NIC isn't getting you anything except another card in the box.
Also I 2nd getting the larger 1TB or even a 2TB drive for storage over the 640.
The Corsair 750TX would be a good fit for your build.
Thank you so much! That should finish out what I need so I can start buying and building next week. The only thing that could change now is possably going with the WD Black 1T for storage. Thanks again!
-D j K i l l a-
Made a few last minute changes to my first/original post. I dropped the Intel LAN adapter since the motherboard comes with two and work just the same as the Intel adapter. I added the Sony Optiarc SATA DVD/CD burner. Everything is retail on the list except for the Sony burner and WD Black SATA 640gb hard drive which are OEM.
Thanks again to everyone who left a comment and took the time to help finalize my build. Unless there's any other suggestions on my build, I start ordering everything Monday-Tuesday this week!
In case anyone is wondering, this build will be running the full install (no upgrade or OEM) of Windows 7 64bit operating system.
-D j K i l l a-
