i7 build. comments? suggestions?
mongerer
This is basically a rundown of what looking to pick up for my i7 rig.
Gaming, some photoshop, looking to really dive into photo editing
Under $1500
3) Where do you live?
Wichita area, KS
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
MB - http://www.newegg.com/Product/Product.aspx?Item=N82E16813188039
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145224
HDD - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Optical Drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173
HSF - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055
Only parts I am reusing is my video card, BFG GTX260 MaxCore 216 and my Creative Labs X-Fi XtremeGamer PCI sound card
6) Will you be overclocking?
Looking for a moderate OC on the 920, pref to 3.4-3.6, possibly on the GTX260, don't see a need to OC the ram
Samsung 22" T220
April/May 08
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Xfire/SLI, able to run multiple gpu's while leaving a PCI-E slot available for other peripherals
10) Do you already have a legit and reusable/transferable OS key/license?
Yes, I still have my Win 7 Beta.
Any suggestions/comments on the above? I basically chose the parts based on what i've read here, I'm also possibly considering that new case Corsair is coming out as well.
It would help to list out the product names alongside the links.
April/May is a ways off and peoples opinions/suggestions will most likely change by then.
Edit: For the 920, if you are only looking for a moderate OC, you probably don't need a huge HSF, or any at all. A lot of people "claim" that they are getting 3.6 or so without changing voltage. If you still want cooling though, go for a cheaper HSF like the Xigmatek Dark Knight:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029 39.99
What Gomit said - please put the name of the items in the post.
you can save about $130 by getting the other EVGA x58 board that is identical aside for the warranty and getting the g skill or ocz 1600 ram.
A week before you buy, make another thread to make sure that you are getting a good system. By April/May, there could be a ton of different hardware out.
