granted im watercooling but im running @ 4.672 with 1.46 volts and ive never seen anything over 71c,,, i know it dont help you much but i honestly think those temps are alittle high especially for that voltage .. try reseating your hsf, i would be honestly scared of those temps and by the way that 71 is after a 8 min Pov-Ray Render with all cores being used on the beta version..
I forgot to mention that I just installed that cpu the same day I ran that test. Maybe the Artic Silver 5 needs some time to settle in?
silver 5 needs 200 hrs burn in...
most modern thermal paste/ grease don't and will get you much cooler than that without the burnin time...
burn in never hurts, but on a side note, very nice case you got thereI ran the test again and got lower temps this time 77c/85c. I think I need to let the AS5 burn in more.
Thanks guys.
