Depends on what you are doing. If you are playing games you can keep your i950 for another couple of years easily.
When will it be in my best interest to upgrade to a newer chip? Is Ivy bridge really that much faster? Or should I wait for the next generation of chips?
Eh if you can wait a bit longer for haswell. Just overclock that I7 950. They were known to hit 4.2-4.3ghz on a regular basis, and thats no slouch when it comes to gaming. I mean 3.3ghz...up that puppy first, then try out Crysis 3
I recently put it at 3.7, and it handles pretty well.
thats pretty good. Try 4, then 4.1 etc etc, Just make sure those temps stay below 80ish (84c is my personal limit).
P.S. Turn off HT, wont help in gaming, and will help you overclock better bye using less voltage for higher clocks.
I would wait till Broadwell or Skylake depending on which one of these are the first to support DDR4.
I'm on i7 870 personally and I'm thinking about holding out for Haswell or later. Don't really have issues w/ my 870 @ 3.7GHz. I see you run your 950 @ 3.3GHz. May want to OC that to help a lil bit.
When you find that your current chip isn't fast enough... Depends on what you do and what your performance expectations are.
I'm on an i7-870 as well (able to clock it to 4GHz fine), but I'm having an issue with my motherboard (I think). The first SATA channel on the board seems to be having issues "losing" my harddrive. At first I thought it was my Vertex SSD, but it still does it occasionally with my Crucial m4 (and I've had no issues with the Vertex on another SATA channel). So it's either a motherboard or a processor thing (I can't remember if any SATA channels are provided by the actual CPU on P55 mobos), so it would be nice for Haswell to go ahead and release so I can move on and stop having this issue, haha.
Haha I'd like to hit 4GHz with mine, but I think having 4 sticks of ram is really limiting my OC. I'm stuck at 3.72GHz but I like how cool my CPU is (idle ~80-90F) vs pumping more voltage. Them SB/IB ppl have OC on easymode.
This might be a total noob question, but what advantages are you gaining by using four sticks of ram on an X58 platform? All LGA 1366 sockets can only access up to 3 channels of memory with the cpu's imc unless I'm missing something.
Is it supposed to be faster than Haswell clock for clock?
