1) What will you be doing with this PC? gaming mainly and some other general use
2) What's your budget? Are tax and shipping included? 2,500 can go a bit over with tax and shipping
3) Where do you live? IL
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific. cpu, mobo, psu, video card, hard drive, optical drive, sound card, ram, case, OS
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. None
6) Will you be overclocking? Not planning to
7) What size monitor do you have or plan to have? currently a 22 inch 1680x1050 but plan to upgrade soon
8) When do you plan on building/buying the PC? next two weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc. sli support just to keep that option open, otherwise nothing crazy
cpu: i7 940
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115201
mobo: asus p6t
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131346
case: coolermaster 690
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
video card: evga gtx280
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130365
psu: antec signature 850
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371018
ram: corsair xms3 6gigs
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145222
hard drive: 300gb raptor
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136260
sound card: creative x-fi xtremegamer
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102005
optical drive: samsung SH-S223Q
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173
My questions
OS: vista 32 bit wouldn't support more than 4 gigs of ram correct?
I'm considering 64 bit but I'm just concerned about compatibility with most programs will that be an issue? I kind of don't understand what all 64 or 32 bit affects.
sound card: is it going to conflict with vista or has creative released some good drivers yet?
I am aware that the psu and video card are total overkill but I want this thing to last. Otherwise any opinions on this would be much appreciated.
cpu: i7 940
mobo: asus p6t
My questions
