i7 920 installation
Burner27
I just got my i7 920 and an Asus P6T Deluxe mobo and I have a question regarding the installation of the CPU. I have done many installs of s775 CPUs but this is my first LGA1366. I lined up the notches on the CPU with the notches in the socket and I am fairly sure it was flat in the socket. When closing the retention mechanism and then trying to lock the arm in place, there seems to be more 'resistance' than i am used to and the arm seems to have a slight bend in it. Is this normal for these LGA 1366 CPUs?
It does put up a decent amount of resistance, yes. I own the combination you're using!
me too and it took slightly more resistance. More so, it was just different so I may just have been overly sensitive anyway.
I thought the same thing.. I thought something was gonna snap as I got closer to the locking mechanism. luckily when it booted up, I was all smiles
How's the P6T6 Revolution doing for you, magnetik?
rock solid. I haven't rebooted since I installed it a week and a half ago. I also tried encoding h.264 while playing FO3. I couldn't tell it was even running. I haven't overclocked at all because coming from the 680i I want to relish it is as much as I can. :D The chipset runs warm but nothing compared to the 680i (even with a chipset fan). random lockups really piss me off. heh So far so good. next upgrades are gonna be an SSD and fill up the rest of the banks with dominators.
Good to hear. I'm having the same positive experience with my Deluxe. 6GB more of RAM, a few more backup disks, and an aftermarket CPU cooler will complete it for now. :)
