Mainly gaming in 1920x1200 max settings but will kick down to 1680x1050 and back off max settings to keep framerates up if needed, web browsing/occasional ripping/general use but nothing heavy.
$1100-$1500 and of course trying to keep as low as possible
3) Where do you live?
South Eastern US (but nowhere near a microcenter so no B&M $200 i7 920 for me
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, MOBO, RAM, GPU, PSU, case, a new ssd drive for os and apps
external dvd burner, external esata cage with 3TB of storage, ,kb, mouse, monitor HP A7217A (Sony FW900) crt
6) Will you be overclocking?
yes but plan to oc as far as i can get without adding any additional voltage if possible.
already have a monitor HP A7217A (Sony FW900) crt
within the next month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Crossfire for future expansion, esata, solid board because I don't want to deal with any flakiness
10) Do you already have a legit and reusable/transferable OS key/license?
Win7 will be on my doorstep around Oct22nd
Here's the current parts list that I'm considering.
Antec Mini P180 Case White (pulling the lower drive cage to have room for the gpu, my dvd and esata storage are all external so the ONLY thing in the case other than cpu/mobo/ram/gpu/psu will be the SSD)
http://www.amazon.com/gp/product/B001CITJGU
Thermalright CoGage True Spirit 4-Heatpipe Core i7 CPU
http://www.frozencpu.com/products/9...rue_Spirit_4-Heatpipe_Core_i7_CPU_Cooler.html
ASUS Rampage II GENE
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131371
XFX HD-585A-ZNFC Radeon HD 5850 (may add a second 5850 next year if needed)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150442
CORSAIR CMPSU-650HX 650W (enough efficient power so that estimated power use for both one 5850 and two 5850's stay nicely in the sweet spot on an overclocked i7 920)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012
Intel Core i7-920 Bloomfield 2.66GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) (solid timings at 1600 and I don't see the need to spend +$100 to try and get 2000 with looser timings from a different set of ram)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145242
Intel X25-M (not sure where I'll get it from, whatever has the best price at the time)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167016
Antec SpotCool (going to be used to cool the northbridge since it runs hot on the rampage)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835209017
CORSAIR CMXAF1 (ram fans, the clips are supposed to hook to each side of the ram clips but the rampage only has clips on one side. Any idea if this will attach properly? If not I could always just add another spotcool for the ram)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835704001
Anyone see any glaring problems? Potential disasters? It's been a looooong time since I built a system but I've been doing a lot of reading here lately to try and catch back up.
