With the help of several here, I'm made a lot of modifications. I'm building this computer for a customer. Budget is $800 (no more). Will be used for light gaming, 3d rendering (Solidworks), photoediting, etc.
Here's what I have so far...
Samsung DVD burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151187
WD Caviar Black 1TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
Antec Two Hundred
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129070
Antec TruePower New TP-550 550W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371020
Intel Core i5 750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
GIGABYTE GA-P55M-UD2 LGA 1156 Intel P55 Micro ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128405
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
SAPPHIRE 100279-1GL Radeon HD 4870 1GB 256-bit GDDR5
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102849
This with the combo deals gets me to $780.
My questions are...
Is the Antec 300 worth the few extra $$$ over the Antec 200 case? Doesn't seem like it.
Are there any other glaring holes? Will the video card fit in the case alright? Is the PSU adequate for this build and maybe future HD and memory expansion?
I appreciate the feedback. I plan to buy everything on Monday. My customer is hot to get something now, because they need it for their home business and the current computer is about dead.
Samsung DVD burner
WD Caviar Black 1TB
Antec Two Hundred
My questions are...
