i5 2500k vs. a8-6600k
dabeeed
Hi,
As the title indicates, I was wondering which processor would be better - in terms of CPU only.
I have a i5 2500k currently and was given the A8 recently from a friend. Is it worth the upgrade? The A8 has a faster Ghz speed, but as I am finding out, that does not indicate best performance.
Thanks!
It's not an upgrade at all. Sell the processor or use it for a different build as a HTPC or secondary system.
A simple google search would have easily answered this for you. The AMD APU's are not even a comparison on the desktop to Intel CPU's. They're simple a low-cost processor with on-chip graphics processing capabilities. Good for mobile, bad for desktops.
http://www.cpu-world.com/benchmarks/AMD/A8-6600K.html
The FX Series is the only series of processors from AMD that come close to challenging just about any i5/i7 chip from Intel. Still they all fall short in most cases.
AMD APUs aren't really power-house CPUs on the processing side.
They sit as all purpose if you can't afford a dedicated GPU.
Or don't need one...still a decent budget system depending on your needs. Either way, not in the same class as a 2500k.
I'd put that A8 in an HTPC if I were you. Put it on an ASRock Extreme6 FM2 (A85X) board and clock it way up high. It'd make for a decent machine. You can put it together for cheap.
I second that. It's what I'd do if someone gave me one. It'd be a nice upgrade from the old laptop I have hooked up to my TV to watch Netflix and occasionally surf the web on.
