Hey guys! I've been looking into build myself a really good gaming computer for awhile now and have finally decided to take the plunge. I started a thread awhile back, but wasn't able to take advantage of the help offered. I'm looking to play Diablo 3 on MAX setting and with that I should be able to play most other games on decent settings.
Here we go:
A little bit of surfing, but primarily for gaming.
I'm looking to spend around $1,500-$1,800 give or take.
I live in the United States just outside of Chicago IL.
Well "Everything" isn't a valid answer, so just about everything. LoL. I'm going to need a case, CPU, RAM, GPU, PSU, motherboard, HDD, and an optical drive. I hope I got everything.
I'll be reusing a keyboard, mouse, and monitor.
6) Will you be overclocking?
I am a complete novice to this, but I'm willing to give it a shot.
7) 7) What is the max resolution of your monitor? What size is it?
Its just a 23 inch 1080p, but I'm looking to upgrade to a 27 inch 2560x1440 soon.
I would like to have it up and running by the end of the month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
I'm not too worried about these features, but if it makes future upgrading easier then I'm all for it.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I'll also need an OS as well.
I know you guys are all for waiting til the end of the month for Ivy Bridge, but MicroCenter has a great deal on the 2500k right now. Thank in advance for any advice/insight on what I should be doing. I look forward to coming back and reading what you guys have to say.
Here we go:
