I will get these components soon ... anything not right ?
Cov
1. CPU - Intel Wolfdale E8400 = £ 152.74
The CPU has to be this one or the Yorkfield Q9450 ... but I don't wanna wait until I'm old.
2. CPU cooler - Zalman CNPS 8700-NT = £ 32.89
I am limited to low profile CPU cooler because there's only 78 mm space between CPU socket & PS.
3. Motherboard - Asus P5E-VM HDMI = £ 83.41
I want mATX ... and I haven't found anything better than this one.
4. Memory - GeIL 4GB (2x2GB) PC2-6400 800MHz = £ 61.09
I'm very unsure with the choice of memory, but it has to be 2GB modules.
By the way, these dragon heads have red LED eyes ... looks awesome.
5. Graphics card - BFG GeForce 8800 GT 512MB = £ 158.50
The choice of the graphics card was very difficult, I'm not sure here.
6. Hard drive - Western Digital 1000GB WD10EACS = £ 133.94
I would love to get SSD but the prices are still utopic. This model here seems to be a smart choice in regards to low noise (variable between 5200 to 7200 rpm) and reliability.
7. Power supply - Silverstone ST50EF-Plus-SC = £ 58.74
This PS is specially made for SFF with shorter cables and temperature regulated fan.
8. PC case - Silverstone Sugo Evolution SG01S = £ 92.83
The choice of PC case was one of the most difficult for me, but I feel good with this case.
9. Monitor - Dell 2408 WFP = £ 440.62
With this monitor the good points seem to outnumber the bad ones.
10. Keyboard = £ 21.09
A question of taste really.
Now this is how you present a potential build thread to the community. ;) Anyway, it looks alright to me. Only possible exception is the ram choice but it'll probably work fine. Should be a sweet little box.
Thank you Skott ... here is the feedback I have had in one of the other forums so far:
1. For a SFF case this CPU appears to be spot on in regards to developing heat.
And even decreasing the frequency and / or the voltage could make this 45 nm dual core CPU ideal for passive cooling, if needed.
Many have recommended to wait for the Yorkfield which is due to be released soon, but as I'm Wolfdale damaged now, I think enough supply might only be available by christmas ;).
2. There are not many low profile CPU coolers but these one seem outstanding ...
  • Zalman CNPS 8700-LED / NT ... 120 x 123 x 67
  • Scythe Shuriken SCSK-1000 ... 65 x 117 x 105
  • Thermaltake Blue Orb II ... 140 x 66 (Heatsink) 120 x 24.3 (Fan)
  • Cooler Master Vortex 752 ... 112.3 x 108.4 x 75.4
  • Silverstone SST-NT06 Lite ... 125.4 x 78 x 148
3. Motherboard ... as I said before.
4. Memory ... some people advise to go for faster RAM. For example G.Skill was recommended. Others think to go for the cheapest memory is absolutely sufficient.
Well, my personal experience is that I always bought the cheapest memory available and it always did what was written on the tin.
5. There seems to be two fan communities ... one for 8800 GT and one for the 9600 GT.
The 8800 fans say that the 9600 couldn't touch the performance of this one.
And the 9600 fans say that the lower power consumption justifies a small loss of performance. Meaning that it makes perfect sense to have little bit performance loss but a lot less heat problems too.
6. I was considering the Samsung Spinpoint F1 series of hard drives as this company has managed to decrease the number of platters what would mean theoretically ...
  • less heat
  • less noise
  • better performance
HD103UJ / 1000GB / 32MB cache / 3 platters
HD753LJ / ..750GB / 32MB cache / 3 platters
HD752LJ / ..750GB / 16MB cache / 3 platters
HD642JJ / ..640GB / 16MB cache / 2 platters
HD502IJ / ...500GB / 16MB cache / 2 platters
HD501IJ / ...500GB / ..8MB cache / 2 platters
HD322HJ / ..320GB / 16MB cache / 1 platter
HD252HJ / ..250GB / 16MB cache / 1 platter
HD251JJ / ..250GB / ..8MB cache / 1 platter
HD162GJ / .160GB / .16MB cache / 1 platter
HD161GJ / .160GB / ...8MB cache / 1 platter
If you now think it could be easy for Samsung to put a fourth or maybe even a fifth platter into this design to create 1.2 and 1.5TB hard drives, I have to disappoint you. While other hard drive families utilize platters that are 50mil (thousandths of inches) thick, the Spinpoint F1 runs on 68mil platters. For this reason, it's physically difficult to simply add a fourth platter to the stack.
The thicker platters are used to increase resistance against vibration.
WD10EACS / 1000GB / 16MB cache / 4 platters
WD efforts to cut the power requirements, like setting rotation speed to 5400+ and intelligent other technics have convinced me so far.
Besides this, my old WD 100GB hard drive, bought in 2001, broke down in 2006. The warranty had expired but after I complained via email WD had exchanged it for a brand new one - free of charge.
This kind of customer services has an effect and so it should be ;).
7. One of the famous PSUs seems to be the Corsair HX520W which I had in my mind but changed to the Silverstone PSU later because of the shorter cables and very good review results too by the way.
8. It really was the hardest desicion of them all for me to find the right PC case.
There are many nice ones out there but I always found something to complain about.
Either it was too big, too unpractical or most of the time just far too ugly.
I found the Lian Li PC-05A very nice until I thought that a mATX motherboard just has to be put into a mATX case ... full stop.
Oh, and I think that those people who love huge monster case bitches are just compensating for something haha ;)
9. The choice of the Monitor is hard too and not really just up to test results on the paper, but if I'd see a model by myself and would be happy with the appearance, I'd go for it ... full stop. Unfortunately there is only litle chance to get demonstrations shown.
10. At the moment I have this Dell keyboard which I'm actually very happy with.
  • less heat
  • less noise
1) Its always better if you can get something that runs cooler and uses less energy but timing a build with what intel releases cannot always be achieved. I dont think you'll be dissapointed with your choice of the 8400.
2)The 8700, BlueOrb II, and the NT06-Lite are the three more popular heatsinks. Which to choose depends on which fits what case. NT06-Lite for quiet running at stock settings. The BlueOrb II or 8700 for those that want to overclock. The NT06-Lite can be modded for a fan but its more work. Which is better between the BO II and the 8700? Got me there. Someone else may be able to tell you.
3)Its the most popular matx right now. Nuff said.
4) If you are running just stock and keeping to a tight budget then nothing wrong going cheap as long as the ram is known to work with the mobo. If OCing however the better quality isnt too much more expensive and worth the price for the performance. DDR2 ram is very cheap right now.
5) I'm one of the 8800GT fans. I dont own a 9600GT nor plan to anytime soon. Most likely I'll jump over the 9600GT and grab something better when it comes out later this year. If I had to choose between the 8800GT and the 9600GT? 8800GT but thats just me. Also depends on pricing. That could sway a person but if performance is key then 8800GT.
6)I had the Spin Series T166 but it crashed on me. It was problematic from the start. It was probably a fluke considering the rave reviews users and professional reviewers were making about it. I prefer WD and Seagate myself because I have had fewer problems overall with them. But you have to go model by model. Both companies make some good units and both companies make some not so good units. You are correct though. The more storage you get per platter and the fewer platters per disc the better. All the drive manufacturers will be doing this. Just depends who does it the best at the time you are wanting to buy.
7)Yes, Corsair is god right now IMO as far as psu goes. However that Silverstone short cable unit is very good quality as well. If it makes fitting all that wiring in there easier then go that route. Frankly both units will make you happy I'm thinking as far as quality and perforamnce goes. Your choice is sound.
8) Yeah, there is no perfect SFF case right now. They have advantages and disadvantages. The ones that seem to have it all are either too big or too expensive. Usually both. So compromising is often involved. I expect case manufacturers to push quality and choice now that the mATX mobos are becoming better overclockers and starting to appeal to people that no longer want big honking tower cases. Larger video cards and better cooling is going to usher in larger mATX cases though I think. Many of the current small SFF boxes just cant hold them and cool properly. The two best that can do it all IMO are the Qmicra V2 and the MountainMod H2g0 but they are large and expensive. For their cost they should be the best.
9) Personal preference really. How big is big enough or too big? Each person must make that choice themselves.
10) Again a personal choice. Mouse and keyboard is something only the user can decide whats good or not.
Again, I think you got a great build planned. Looking forward to seeing pics of it when done. :)
