Originally posted by Laforge
Uhm.. that's not going nuts at newegg
VVV points to sig VVV
with all that stuff get yourself a higher psu, like a 480Originally posted by devo5676
yea im about to go nuts a new egg as well.....
-Thermaltake Highest Xaser III v1000A(cooling for OCing)
-Gigabyte 875P chipset model:GA-8Ik1100
-ATi Radeon 9800 Pro 128DDR
-ATi Tv wonder pro
-Antec True 380w power supply
-P4 3.0c 800mhz FSB HT ready
-Geil 2x512 (1gb) pc3500 DDR433
-Maxtor 160GB harddrive 8mb cache
-Veiwsonic Perfect flat 17inch and a 19inch(dual monitor)
-and Sony cd-rw dvd rom 48-24-48-16
any suggestions?
Originally posted by SKiTLz
And the no money thing is no excuse. That's why they have Credit Cards..(or line of credit if your doing some serious debt buying)
Originally posted by SmokeRngs
Those two things are two of the main reasons I don't have any money.![]()
You and me both!who would have known paying one line of credit off with another wasn't a smart thing to do? (and no the interest rate is no better)
Originally posted by MrFace
snip
Yay!
Bout time I stopped using a 4x Cd rom and a 40 gig hd.![]()
Originally posted by emorphien
Get the 256 9800 if you can. It may or may not be necessary in the near future with DX9 games and more detailed textures but it couldn't hurt. It's only $40 more and since I just returned my $300 9800 pro 128 to Best Buy I'm waiting on a $342 9800 pro 256mb from newegg (free shipping).
I can live with the slightly higher price (whopping $20) so it's not a bad deal for me. If you can swing it I might suggest you try to do so.
edit: Alternatively, if you have to get the video card I think you can get a 9800 pro 128 AIW for less than the combination of the 9800 pro and a tv tuner, just shop around. Maybe even newegg can do that. Dunno.
I also haven't heard great things about the cooling from the Xaser cases, but I'm not really sure. Read up on it.
Originally posted by weset
with all that stuff get yourself a higher psu, like a 480antec ofcourse
well i currently am employed at bestbuy so if they are coming out with the 9800 256 there i'll just pick up with my discount...... but i'll probably just get it at new egg, prices are usually cheeper!
Originally posted by Dome
i'm sitting on a wishlist til i get back to school, i just finished it yesterday so i wanna make sure its sound and worth the money, plus i'm waiting til i get back to school to order it.
antec soho 1040BII w/ 400 watt smartpower
abit nf7-s
barton 2500 oem
radeon 9800 pro built by ati
2x 256 kingston hyperX pc 3500
zalman cnps7000 alcu hsf
artic silver ceramique
2x coolermaster case fans
total w/ shipping (if i can add properly) is $800.45
i already have 2 harddrives, and a cdrw and floppy from my old system, along w/ peripherals and monitor. i'll probably just use onboard sound but i got an audigy if i decide againt it.
frankly i can't wait![]()
Originally posted by hi_its_ryan
i dont want to be rude, but what is it with all these people buying expensive video cards and RAM and mobos that are going to be almost obsolete by Q3 2004?
PCI-Express and DDR-II mobos with the new chipsets will become the standard fairly soon, save your money!! myself, i'm going to keep my stodgy old 9700 pro until summer at least, when i'll start purchasing the new shite /me crosses figures and prays that the prescott o/c's like a bat out of hell
and dont forget the new BTX standard........
your waiting to get back to school so u can add the total correectly?Try a calculator.
Originally posted by DarkSiDe
This is what I did for xmas..(gift to myself)..and wife swears I am nuts..But we all know how we do..
Asus K8T800 Chipset Motherboard for AMD Socket 940 CPU, Model "SK8V" -RETAIL
Specifications:
Supported CPU: Single Socket 940 AMD Athlon64 FX Processors
Chipset: VIA K8T800 + VIA VT8237
FSB: Scalable HyperTransport
RAM: 3x DIMM for Registered ECC DDR400/333/266 Max 8GB
IDE : 3x UltraDMA 133 up to 6 Devices
Slots: 1x AGP 8X, 5x PCI, 1x WiFi
Ports: 2xPS2, 1xLPT, SPDIF Out, 1xCOM, 8xUSB2.0(Rear 4), 1xLAN, 2xIEEE1394(Rear 1), Audio Ports
Onboard Audio: ADI AD1985, 6-channel CODEC
Onboard LAN: 3COM 3C940 Gigabit Ethernet
Onboard SATA/RAID: 2x SATA, RAID0/1; 2x SATA, RAID 0/1/0+1(Total 4 Serial ATA)
Asus RADEON 9800XT Video Card, 256MB DDR, 256-bit, DVI/VIVO, 8X AGP, Model "9800XT/TVD" -RETAIL
Specifications:
Chipset/Core Speed: RADEON 9800XT/412MHz
Memory/Effective Speed: 256MB DDR/730MHz
BUS: AGP 1X/2X/4X/8X
Ports: VGA Out(15 Pin D-Sub)+VIVO+DVI connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: VGA via DVI Adapter, VIVO Adapter, CD Box, Manual
Max Resolution@32bit Color: 2048X1536@85Hz
Retail Box (See pics for details) more info-> N82E16814121500
Antec 480W Power Supply with Blue LED Fan, Model "TRUE480BLUE" -RETAIL
Specifications:
Type: ATX
Maximum Power: 480W
PFC: No
Power Good Signal: 100-500ms
Hold-up Time: >17ms at Full Load
Efficiency: >68%
Over Voltage Protection: +5V trip point<+6.5V;+3.3V trip point<+4.1V;+12V trip point<+14.4V
Overload Protection: Latching Protection+5V @<47A;+3.3V @ <48A;+12V @ <18A
Input Voltage: 115 VAC / 230VAC
Input Frequency Range: 47-63 Hz
Input Current: 5.0A for 230VAC
Output: +3.3V@30A;+5V@38A;-5V@0.5A;+12V@22A;-12V@1.0A;+5VSB@2A
MTBF: 80,000 hrs. @ 25ºC
Approvals: UL, TUV, CB, VDE, FCC CLASS B, DEMKO, NEMKO, SEMKO more info-> N82E16817103914
AMD Athlon 64 FX-51, 1MB L2 Cache, The Only Windows Compatible 64-bit Processor - Retail
Specification
Model: AMD Athlon 64 FX-51
Core: ClawHammer
Operating Frequency: 2.2GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/1024K
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 940
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included) more info-> N82E16819103415
OCZ Enhanced Latency Dual Channel Gold 184 Pin 1GB(512MBx2) DDR PC-4000 - Retail
Specification
Manufacturer: OCZ
Speed: DDR500(PC4000)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5-4-4-7
Support Voltage: 2.8V
Bandwidth: 4.0GB/s
Organization: two 64M x 64 -Bit
Special Features: Ultra Low Noise shielded PCB
Warranty: Lifetime more info-> N82E16820146934
2x Raid Western Digital Raptor 74GB 10,000RPM SATA Hard Drive, Model WD740GD, OEM Drive Only
Specifications:
Capacity: 74GB
Average Seek Time: 4.5 ms
Buffer: 8MB
Rotational Speed: 10000 RPM
Interface: Serial ATA
Features: High Performance SATA Interface
Manufacturer Warranty: 1 year
Remark: OEM Drive Only more info-> N82E16822144160
Western Digital 250GB 7200RPM IDE Hard Drive, MODEL WD2500JB, OEM Drive Only
Specifications:
Capacity: 250GB
Average Seek Time: 8.9 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: IDE ULTRA ATA100
Features: High-Performance with 8MB Buffer
Manufacturer Warranty: 3 years
Remark: OEM Drive Only more info-> N82E16822144309
Plextor Black 8X DVD-RW/+RW Drive, Model PX-708A/SW-BL, Retail
Specifications:
Model: PX-708A/SW-B
Write Speed: 40X CD-R, 24X CD-RW, 8X DVD+R, 4X DVD-R, 4X DVD+RW, 2X DVD-RW
Read Speed: 40X CD-ROM/CD-R, 12X DVD-ROM
Interface: Internal IDE
Buffer: 2 MB
OS Support: Windows XP/ ME/ 2000/ 98SE
Features: Lossless linking technology, Buffer Underrun Proof technology
Remark: Retail Pack (see pictures for details) more info-> N82E16827131311
LITE-ON BLACK 16X DVD ROM Drive, Model XJ-HD166/XJ-HD 165H, OEM
Specifications:
Read Speed: 48X CD-ROM, 16X DVD-ROM
Interface: E-IDE/ATAPI
Buffer: Not specified
Access Time: 120ms ( typical )
Data Transfer Rate: DVD-ROM 8600~21600 KB/sec, CD-ROM 3000~7200 KB/sec
Features: SMART-X Technology, Easy-Tray Design for Both Horizontally & Vertically Use
Remark: OEM (see pictures for details
$3,214.98 Out the Door to my house..I also bought Black CoolMaster Wave Master Case to put it all in..NICE![]()
JESUS CHRIST, that is crazy dude, im at a under 2k limit, lol
