I was sooooooooooooo close (davinci resolve)!
If you're running an AMD GPU, you'll need AMD's ROCM software installed for just about anything to utilize the GPU outside of gaming. For CachyOS the package is opencl-amd included in the AUR assuming you're running the open source drivers for the video card included with the kernel. Just because the program can see the GPU is there doesn't mean it can utilize it if the proper software isn't installed already.
Folding@Home under CachyOS can see my GPU just fine but it can't fold on it unless I have the opencl-amd package installed for ROCM.
Those instructions are assuming it's an AMD GPU and newer than Polaris. I still have a Polaris I use occasionally for distributed computing and it requires a specific version of opencl-amd to work because AMD completely removed the ability in versions after this specific one.
Just to expand on this, as I think it's important that newcomers become comfortable with using their package manager via terminal; using an AUR helper like 'paru' which is included with CachyOS, the command would be:
Code:
paru opencl-amd
The result would be as follows:
Code:
❯ paru opencl-amd
1 aur/opencl-amd 1:7.2.0-1 [+137 ~0.68]
    ROCm components repackaged from AMD's Ubuntu releases (ROCr runtime, OpenCL runtime, HIP runtime) - This package
    is intended to work along with the free amdgpu stack.
2 aur/opencl-amd-dev 1:7.2.0-1 [+13 ~1.72]
    ROCm extra runtime and developer packages. This package needs 14.03GB of disk space.
3 aur/xmr-stak-opencl-amd 2.10.8-1 [+2 ~0.00] [Out-of-date: 2024-03-28] [Orphaned]
    Unified All-in-one Monero miner (AMD)
:: Packages to install (eg: 1 2 3, 1-3):
Select option 1 and follow the prompts to install.
Thx, I hit option 1, still crashes on edit tab. There is something else going on.
You might still have "bad/outdated" libraries installed from the run binary. I recommend running DR from a terminal & see what it says. If there's a verbose switch, that might work best to get more info.
Ok I did that CMD launch and I didn't see any errors and it crashed when I breathed on the edit tab. So as a last resort I use Goggle Ai. L-O-L
And the answer I got fixed it. Mrgovernment was right on it from the begining. It was the MESA stock drivers. so I uninstalled them and installed the rocm and BOOM it worked.
Google Ai answer.
Then inside DR working on a MP4 vids that don't work due to no codex as already stated. but worked and no crash. I guess I need to get handbreak and figure out how to use that now.
Huge thanks for everyones help.
What's not user friendly regarding the setup?
To guarantee compatibility with DaVinci Resolve on Linux, use these settings in HandBrake:
Container: Select MKV (best for compatibility with Linux codecs) or MOV.
Video Codec: Select VP9 or DNxHR. Note: Do not use H.264/H.265 if you are using the free version of Resolve, as it often fails to decode them on Linux.
Framerate (FPS): Choose Constant Framerate and select "Same as source" to avoid audio/video sync issues in your timeline.
Quality: Use Constant Quality (Constant Rate Factor - CRF).
For high-quality editing, set the RF slider between 15 and 20 (lower is higher quality).
Audio: Set Audio to PCM or FLAC to ensure audio compatibility.
Hey I followed your instructions and I must be doing something wrong. I start with a 1.5GB MP4 file and ended up with a 14GB .mov. I then tried the .mkv and it said 18 minutes, i was like grrrrrrrrr.
You should be ending up with an MKV, not an MOV. Are you converting to Matroska via the Summary tab > Format drop down > Matroska (avformat)? Furthermore, your overall file size should be about the same or slightly lower - my example was 150MiB smaller in size after converting.
Yes, converting to MKV will take time, transcoding is a demanding process.
Ok thanks, I was doing it right. It would take a ton of time for me to convert all my files that are in 4GB files 10 at a time. Looks like I am stuck with windows till I spend 300 bucks and get the full ver, which is well well worth the money.
I did some cmd line conversion to convert .mp4 to .mov and it went fast but doubles the file size. crazy.
