I think something is seriously wrong with my PC! Help
reveille_83
I have a newly computer just built. I believe I am having some stability problems.
I have attempted to run Prime95 and SP2004.
More than one CPU detected.
You should run two copies of SP2004 simultaneously.
Type: Blend - stress CPU and RAM Min: 8 Max: 4096 InPlace: No Mem: 1791 Time: 15
CPU: 2216MHz FSB: 200MHz [201MHz x 11.0 est.]
5/30/2006 12:53 AM Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
FATAL ERROR: Rounding was 0.4999497956, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 0 minutes 4 seconds - 1 errors, 0 warnings.
Execution halted.
Is the message I get while running SP2004. Prime95 crashes in about 4 seconds upon running the torture test.
Here are my specs for my machine:
CPU: AMD Athlon 64 X2 4200+ (Manchester)
MB: Asus A8N-SLI
RAM: Corsair XMS 1GBx2 PC3200
HDD: Western Digital Raptor 150GB
P/S: AeroCool 620 Watts
Video: Asus EN7900GTX 512MB
Sound: Audigy
I am not even sure where to begin. I am currently running 2.90 voltage on the memory because anything lower and I get missing file errors when trying to install Windows XP Professional SP2. I will let you know what BIOS version I am running.. Any help is greatly appreciated
nay. The only thing that is touched is DDR voltage. It is currently 2.90 because anything lower gives the missing file error when installing an Operating system.
Um, if you have to tweak voltages on memory to get your system to install, you NEED to RMA that ram. Something is wrong with it. That is why you are getting prime95 and sp2004 errors.
i updated my bios version to 1014.2. still having problems. i am about to run memtest to see what happens.
can you elaborate more on why my memory is bad if i have to adjust the voltage?
Yes run memtest, and hopefully that will confirm the suspisions that your RAM is bad. What the other guy ment is that your RAM voltage shouldnt have to be set at 2.9V to just install Windows. Be carefull with that RAM, 2.9V is quite a bit of voltage. Run memtest to verify but it sounds like you got some bad RAM.
You should never have to adjust voltages to get your system to run out of the box unless you're overclocking. The default voltages should run perfectly The fact that you needed to tweak the voltage just to get the system to install is a sure sign that the particular piece of hardware is faulty.
After thinking on this more, If memtest comes back clean it's entirely possible the motherboard has isses as well.
And when you run Memtest, let it run overnight...a good 12hrs, unless it comes up with errors sooner.
RMA the memory. If the memory doesn't run as it should, at described settings and the voltages it is supposed to use then it is bad. You don't need to test it or run anything. Just RMA it.
update:
memtest86 is at about 10 hours and still running strong. i am currently running memtest86 at DDR voltage at 2.9. If this run completes with no problems I am going back to the default settings of the bios and proceeding to run memtest86 again and I will give an update after completion. Is it possible that my bios version is causing problems? I have read on a few forums that some of the newer revisions of the bios is having problems?
what else could it possibly be?
also,
i have run HL2: Lost Cost Stress test several times and haven't been having any stability problems. Is it possible that my computer just doesn't like prime95 or sp2004? are there any other programs i could run that would diagonse problems?
Perhaps try checking its voltages in BIOS, though that RAM still does seem pretty wonky if you need to up its voltage to even install Windows.
update:
Reset bios to default. DDR voltage set to [Auto]
1 hour after running Memtest-86. I have gotten 2 error messages.
I am not sure what it means so I will copy it here.
Tst/ Pass/Failing Address/Good/Bad/Err-Bits/Count
5/1/00028677f48 - 646.4MB/00020008/00000008/00020000/1
5/1/00029677f28 - 662.4MB/00020008/00000008/00020000/1
8/1/00020c77ee8 - 524.4MB/0000000/00020000/00002000/1
8/1/00025277ee8 - 594.4MB/0000000/00020000/00020000/1
So if I can have an opinion on wether this is bad memory or not I will RMA it. I thank you very much for your time
I would RMA it. You should never get errors in memtest with stock memory that quicky (or perhpas at all?)
update:
i am RMA'ing the memory. i am hoping this is all that is wrong. can anyone comfort me? :( this isn't the first time i have had memory woes :( why can't they just make this stuff work
Did you change any of the timings on the RAM or did you leave them all at default?
If the timings where at default settings then yes you should RMA the RAM. Memtest should run flawlessly for hours error free.
That RAM is fine in repsects it will work on either AMD or Intel.
And, coolxboxgamer you should know that judging by your specs in your sig.
Got my new ram today from Newegg. My computer works flawlessly on Prime95.
I believe my problem is solved. Thanks again to all the help!
reveille_83 said:
update:
Would you like a hug?
/not really
/been there and felt the pain
If I had to guess at the probability that the mem was the culprit, I'd say you are at a strong 90%. If, when you receive the new mem, you still have the same problem, I would suspect the mobo is flakey and isn't providing the voltages it says it is.
The only other thing I can think to check is that the mobo is auto detecting your timings correctly on that mem. The mem I have in my box now didn't auto detect properly forcing me to manually configure it in the BIOS for it to work properly.
/not really
LOL, nice prediction.
