RadioActiveLobster
- Mar 20, 2010
I'm getting tired of my current desk. It was a cheap one from Ikea I bought several years ago and it's getting to the point I just hope it doesn't collapse on me and destroy my monitors.
I decided instead of spending a bunch of cash on a desk and triple monitor arm I am going to build one out of some lumber I have setting around.
I'm not going for pretty, but for function. I'll end up sanding it down, staining it and what not but I am perfectly find with the legs being nothing more than 2x4's.
I threw together some quick mockups with Google Sketchup (first time ever using that program, so they arn't great) but they show the general idea..
I just wanted to get you guys/gals thoughts or comments on things I can improve, possibly the best way to mount the monitors (they have standard 100mm VESA mounts on the back, I'm thinking of just throwing something together out of some angle iron or steel tubing I have laying around and possibly making mounts myself or finding some cheap)
Everything here is basically to scale, the measurements are ballpark ones for right now (especially on the hight of the monitors, etc..) I need to keep the entire thing under 67 inches length wise and width wise about 30 inches as I don't have much room to work with.
CLICK FOR LARGE IMAGES
What do you think?
What do you think?
